cigarette lighter jack toggle switch - Cobalt SS Network
Thread Tools Search this Thread
Old 01-28-2009, 12:18 AM   #1
long story short:
i hate leaning forward and turning my radar detector (passport 8500 x50) on and putting it at the volume i like every single time i start my cobalt and then when im about to jump out leaning forward and turning it off.
i want to be able to cut the power off to the cigarette lighter jack via toggle switch so i can just hit the switch right there on and off easy
kinda like in this pic:
now i have this toggle switch:
its rated 3amps at 125v
ive googled trying to find a converter or something to see the amp rating converted from 125v to 12v could not find anything
is this switch safe to use?
i went to autozone there switches were rated at 12v but all they had were huge flashy ricer switches
i want to have a small toggle switch like in the first pic above
and i really want to do it this way
please give me your advice and suggestions
thank you
Sp0rkeh is offline   Reply With Quote
Old 01-28-2009, 12:19 AM   #2
Original Hayden Fanatic
REIGN SS's Avatar
Images: 93
get an hardwire kit made your the detector, use an add-a-fuse and tap into the sunroof.
REIGN SS is offline   Reply With Quote
Old 01-28-2009, 12:21 AM   #3
ive searched the forums about it and found that yes tapping the sunroof will have it turn on and off with the car
quote myself: and i really want to do it this way
Old 01-28-2009, 01:10 AM   #4
EmperorJJ1's Avatar
Images: 315
so you wanna tap the cig lighter still or hardwire the radar detector? you can put that switch on the cig lighter but its not going to be very "safe"
EmperorJJ1 is offline   Reply With Quote
Old 01-28-2009, 01:14 AM   #5
Images: 57
Basically what hes going to do is keep the detector plugged into the cig lighter at all times. But since our cig lighters don't turn off when the car is turned off, hes going to put a switch in the power line of the cig lighter to cut power completely to the lighter so he can just flip the switch isntead of unplugging everytime.
BigTizzle903 is offline   Reply With Quote
Old 01-28-2009, 01:18 AM   #6
EmperorJJ1's Avatar
Images: 315
i know but if your running power thru that switch its going to melt and hopefully pop the fuse, otherwise melt that power wire until something stops current from flowing
it would be safer to put the switch in line with the ground but overall not "safe"
Old 01-28-2009, 01:19 AM   #7
Images: 53
thank you
in the aisle with all the fuses and electrical connections they should have regular 12v switches like that, I work at an autozone and we don't just have the ricer ones.
c0ld29 is offline   Reply With Quote
Old 01-28-2009, 01:25 AM   #8
Why not leave in plugged in all the time. It can't possible drain anything, mines been that way for two years. Just, wondering.
Durtyss is offline   Reply With Quote
Old 01-28-2009, 01:25 AM   #9
Images: 57
That's a good point. When I say power line the ground wire works just as well. Just something to stop the juice from flowing to the cig lighter.
Old 01-28-2009, 02:10 AM   #10
common guys this isnt hard or anything to freak out about
its very simple its just DC current the current is broken by a switch we learned this in elementary school
imagine the socket being a light bulb. what do you have? a lamp.
nothing is going to fry, burn or explode
all its doing is turning it off and on
Old 01-28-2009, 02:51 AM   #11
EmperorJJ1's Avatar
Images: 315
right and how much power has to flow thru that switch? it can only handle so much before it reaches its melting point
Old 01-28-2009, 03:21 AM   #12
did you even read my first post?
that is why i made this thread was to ask if witch switch is safe
quote myself from first post again: is this switch safe to use?
jeez i wish people would actually read instead of just spamming posts to increase their post count
if no one knows if the switch i already have is safe please suggest one
like i said in my first post i went to autozone but they only had huge ones
im looking for a small safe to use one
in the morning im going to check some other autopart stores they might have a bigger selection
Old 01-28-2009, 03:29 AM   #13
EmperorJJ1's Avatar
Images: 315
i did and responded on post 4 the other 2 were responses to the other peeps in this thread
if your looking for safe then you need a relay otherwise good luck finding a switch thats 10-15a, 12v... even if you did it would be giagantic
http://www.amazon.com/Push-Pull-Swit.../dp/B000Y8495K
1in enjoy
Old 01-28-2009, 03:44 AM   #14
would the switch have to be that hardcore if just the radar detectors amperage is going through it?
im sure a radar detectors amperage should not be to much more than the amperage of an ipod or something right?
its just a small electrical device
Old 01-28-2009, 08:42 PM   #15
Update
after some brainstorming:
i thought it would be easier to put the switch on the plug thing :P
took it apart did some drilling and soldering
escort toggle switch mod:
in the cobalt:
conclusion:
took about an hour to do
it works
no more leaning foward to turn on/off and finding the volume i like every time
easy just tap the switch on and off
Old 01-29-2009, 01:26 AM   #16
EmperorJJ1's Avatar
Images: 315
awesome idea, to answer the question if a smaller one could be used yes but once you plug something else in there that draws more power you may run into issues.... putting the switch on the radar adapter itself pretty much eliminates that issue. Im not sure how much current the passport draws but its probably under the 3a the switch is rated for
Old 02-02-2009, 11:47 PM   #17
koch1ar's Avatar
Images: 6
how did you find out about this mod
koch1ar is offline   Reply With Quote
Old 04-13-2010, 10:51 AM   #18
Modernceo's Avatar
Ive got this exact same problem with my 09 Cobalt SS. Ive got a bluetooth device for my iphone in the Cobalt and when the car is in my garage, its constantly powered and it creates problems for me.
I think im going to put a switch in line. Or I might even put a relay in line to the cigarette lighter so that its turned off automatically when the cars turned off.
GM should have wired our cars so that the cigarette lighters power off when our cars are turned off.
Modernceo is offline   Reply With Quote
Old 04-13-2010, 12:47 PM   #19
EmperorJJ1's Avatar
Images: 315
i probably wouldnt do an inline switch. but a relay would work well.
lol im glad gm left the cig lighter constant. but i really dont use it anyway. just have my relay for the amps tapped off it
Old 04-13-2010, 12:56 PM   #20
Images: 2
If he does not get a switch rated for the current that a cigarette lighter pulls then yes it will burn, melt, and cause an issue.
Edit: Entered before the OP updated.
crypticscifer is offline   Reply With Quote
Old 04-13-2010, 11:37 PM   #21
Images: 23
ummm... so now u have to reach by the cig outlet and just flip a switch, correct? in my eyes thats kinda pointless cuz instead of spending that hour plus to solder that switch in you could just unplug the thing cuz u have to reach down there anway... but ok i guess... i just wired my radar detector into my fuse panel with one of those add a fuse deals and it works great. i forget which fuse i tapped into tho... prob the sunroof im guessing. it took all of 20 min for me to do, and it only took that long cuz i took a break to have a smoke and pound down a beer, haha.
chitala383 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Issues with LNF with Vac and random KR Sl0wbaltSS 2.0L LNF Performance Tech 17 11-17-2016 01:59 PM
Trying to find a Tech 2 for VIN Relearn in SoCal agentirons Electronics, Audio, and Video 2 10-16-2015 03:11 AM
Recommended tools for a beginner. tuned08ss The Lounge 34 10-02-2015 07:14 PM
For Sale Evo 8, built bottom end, big turbo, for trade Cptnslo Complete Cars 9 09-24-2015 10:32 AM
Radio and cigarette lighter doesn't work shawnsseries Electronics, Audio, and Video 3 09-10-2015 09:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
