Cobalt Audio Pinouts
  • Quote: Amplifier and Radio pinouts, circuit ID's, color codes:
    Audio Amp. Connector1
    Connector Part Information
    • OEM: 12110088
    • 24-Way F Micro-Pack 100 Series (GY)
    Pin
    Wire Color
    Circuit No.
    Function
    A1
    L-GN/BK
    1794
    Left/Rear Subwoofer Speaker (-)
    A2
    D-BU/WH
    346
    Left/Rear Subwoofer Speaker (+)
    A3
    L-BU/BK
    115
    Right Rear Speaker Signal (-)
    A4
    D-BU
    46
    Right Rear Speaker (+)
    A5
    BN
    199
    Left Rear Speaker (+)
    A6
    YE/BK
    116
    Left Rear Speaker Signal (-)
    A7
    D-BU
    546
    Right Rear Low Level Audio Signal
    A8
    BN/WH
    599
    Left Rear Low Level Audio Signal
    A9
    TN
    1946
    Right Rear Low Level Audio (-)
    A10
    BN
    1999
    Left Rear Low Level Audio (-)
    A11
    D-GN
    117
    Right Front Speaker Signal (-) (1)
    A12
    L-GN
    200
    Right Front Speaker (+) (1)
    B1
    L-BU/BK
    315
    Right Subwoofer Speaker (-)
    B2
    D-GN
    1795
    Right Subwoofer Speaker (+)
    B3
    D-GN
    1947
    Left Front Low Level Audio (-)
    B4
    L-GN
    1948
    Right Front Low Level Audio (-)
    B5
    TN
    511
    Left Front Low Level Audio Signal
    B6
    L-GN/WH
    512
    Right Front Low Level Audio Signal
    B7-B10
    Not Used
    B11
    GY
    118
    Left Front Speaker Signal (-) (1)
    B12
    TN
    201
    Left Front Speaker (+) (1)
    Audio Amplifier Connector2 (UQ3)
    • OEM: 12110626
    • 8-Way F Metri-Pack 280 Series (L-GY)
    Pin
    Wire Color
    Circuit No.
    Function
    A
    BK/WH
    1051
    Signal Ground
    B
    BK/WH
    1051
    Signal Ground
    C
    Not Used
    D
    L-GN
    1011
    Remote Radio Control Signal
    E
    PK
    314
    Radio On Signal
    F
    Not Used
    G
    RD/WH
    640
    Battery Positive Voltage
    H
    RD/WH
    640
    Radio C1
    • OEM: 12110206
    • Service: See Catalog
    • 24-Way F Micro-Pack 100 Series (L-BU)
    Pin
    Wire Color
    Circuit No.
    Function
    A1
    GY
    118
    Left Front Speaker Signal (-) (1) (U1C)
    A1
    D-GN
    1947
    Left Front Low Level Audio (-) (US8)
    A2
    TN
    201
    Left Front Speaker (+) (1) (U1C)
    A2
    TN
    511
    Left Front Low Level Audio Signal (US8)
    A3
    L-BU
    115
    Right Rear Speaker Signal (-) (U1C)
    A3
    TN
    1946
    Right Rear Low Level Audio (-) (US8)
    A4
    D-BU
    46
    Right Rear Speaker (+) (U1C)
    A4
    D-BU
    546
    Right Rear Low Level Audio Signal (US8)
    A5
    BN
    199
    Left Rear Speaker (+) (U1C)
    A5
    BN/WH
    599
    Left Rear Low Level Audio Signal (US8)
    A6
    YE
    116
    Left Rear Speaker Signal (-) (U1C)
    A6
    BN
    1999
    Left Rear Low Level Audio (-) (US8)
    A7
    L-GN
    200
    Right Front Speaker (+) (1) (U1C)
    A7
    L-GN/WH
    512
    Right Front Low Level Audio Signal (US8)
    A8
    D-GN
    117
    Right Front Speaker Signal (-) (1) (U1C)
    A8
    L-GN
    1948
    Right Front Low Level Audio (-) (US8)
    A9
    D-BU
    1796
    Steering Column Radio Control Signal (UK3)
    A10
    WH/BK
    644
    10-Volt Reference (US8)
    A11
    Not Used
    A12
    BK/WH
    1051
    Signal Ground
    B1
    RD/WH
    1140
    B2
    Not Used
    B3
    L-GN
    1011
    Remote Radio Control Signal (US8)
    B4-B5
    Not Used
    B6
    PK
    314
    Radio On Signal
    B7-B8
    Not Used
    B9
    D-GN
    5060
    Low Speed GMLAN Serial Data
    B10-B12
    Not Used
    Radio Connector2
    • OEM: 12064799
    • 12-Way F Micro-Pack 100 Series (BK)
    Pin
    Wire Color
    Circuit No.
    Function
    A-G
    Not Used
    H
    D-GN/WH
    368
    Right Audio Signal (+)
    J
    BN/WH
    367
    Left Audio Signal (+)
    K
    TN/WH
    372
    Audio Common
    L
    OG/BK
    2061
    Cellular telephone voice Low Reference (UE1)
    M
    PK/BK
    2062
    Cellular Telephone Voice Signal (UE1)
    relevant RPO descriptions:
    UK3
    Control, Steering Wheel, Accessory
    UN0
    Radio, AM/FM Stereo, Seek/Scan, CD, Auto Tone, Clock, ETR
    UQ3
    Speaker System, Performance Enhanced Audio
    UQ4
    Speaker System, 4, Base
    US8
    Radio, AM/FM Stereo, Seek/Scan, CD, Auto Tone, Clock, ETR, MP3, RDS
    U1C
    Radio, AM/FM Stereo, Seek/Scan, CD, Clock, ETR
    U2K
    Digital Audio System S-Band
    UE1
    Communication System, Vehicle, G.P.S. 1
    the radio DOES communicate on the Lowspeed GM-LAN line, it recieves VIN information for TheftLok, illumination dimming inputs, and signal for speed compensated volume.
    Some audio functions are available using the steering wheel controls. The steering wheel controls are actually a resistor network which consists of multiple momentary contact switches and a series of resistors. The switches and resistor network is arranged so that each switch has a different resistance value. When a switch is pressed, a voltage drop occurs in the resistor network which produces a specific voltage value unique to the switch selected. These specific voltage values allow the radio to identify which switch has been pressed. The radio responds just as if the corresponding radio front panel button had been pressed.When the radio is ON, the radio supplies approximately 10 volts to the switches on the 10-volt reference circuit. The specific voltage signal from the switch is returned to the radio on the steering wheel controls signal circuit.This may inhibit the use of the redundant control with an aftermarket head unit.
    (Gm Service Information 2005 Chevrolet Cobalt)
    Some of you may have been aware of this information, many of you may not have, hope it helps any who need it.
    __________________
    ASE certified Master Technician
    ASE certified Advance Engine Performance Specialist
    General Motors certified Technician
    General Motors Mark of Excellence Platinum ranked(engine repair)
    I figured this should be a sticky
