Door chime not working properly?
Old 08-25-2014, 09:05 AM
Hz13's Avatar
06 LT coupe, When the door is open the door ding sounds constantly even if the lights aren't on and there is no key in the ignition. Is this normal?
blueLNFftw's Avatar
no
Old 08-25-2014, 09:09 AM
Hz13's Avatar
no
Figured. Any idea what it could be?
Old 08-25-2014, 09:28 AM
yellowsupercharged06's Avatar
move this to problems section
Old 08-25-2014, 09:29 AM
blueLNFftw's Avatar
It is definitely broken
Old 08-25-2014, 09:49 AM
Old 08-25-2014, 10:04 AM
Way to help out a new member
Old 08-27-2014, 12:04 AM
EmperorJJ1's Avatar
the better question is where do the chimes even come from? In an 06 the speaker is in the speedo so maybe replacing the speedo would fix it (if whatever tells the speaker to make noise is all inclusive in the speedo) but if not the only other thing id think it could be is the bcm. that would be a pretty expensive fix for some chimes
Old 08-28-2014, 12:11 PM
Hz13's Avatar
Sorry if this is in the wrong section.
Anyway, I don't think I want to spend all that just to fix a stupid door ding. I need to get the ignition switch recall done. Any chance that might remedy my issue?
Old 08-28-2014, 12:21 PM
qwank's Avatar
yes, if the little tab in the cylinder that the key pushes against when it's in is stuck, the new cylinder will fix the problem. The tab pushes against the ignition switch, so if that's shorted or stuck, the new switch could fix it also.
I would have the recall done first before diagnosing anything any further.
Solaris99
28
03-15-2017 01:22 PM
dennis69
10-20-2015 04:49 PM
SSLOW06
10-01-2015 07:21 PM
Delta coupe
09-30-2015 08:11 AM
DocSvensk
09-27-2015 02:24 PM
Quick Reply: Door chime not working properly?
