Electronic Power Steering Module - Cobalt SS Network
Thread Tools Search this Thread
Old 03-19-2017, 12:55 AM   #1
Exclamation Electronic Power Steering Module
Hello,
I have a 2006 Cobalt SS 2.0 S/C that had a bad electric power steering pump. I pulled off the motor and replaced it with a used one and it still didn't work. Both motors were tested using a car battery and both worked. I went to the junk yard and got a complete pump I swapped it out and now my car wont turn on. I have a security light on that won't turn off. I took my old pump and took off the module from it I had to cut off the wires that go into the pump as they cannot be taken off. I plugged it into my car and my car turned on and the security light went off. As soon as I plugged the replacement part the security light goes on and my car wont start. How can I reprogram the module so my car can start? Thanks in advance.
P.S.
I don't know if I posted this on the right place, correct if need be. Thanks!
blackstar is offline   Reply With Quote
Old 03-19-2017, 01:27 AM   #2
Images: 4
you need to do a security relearn.
roll the drivers window down, reach through and turn the key on, leave it for 10 minutes or till the security light goes out. shut the key off, then turn it back on, wait another 10 minutes, shut the key off, turn back on for a final 10 minutes, then turn the key off. after that the car should start. its advisable to have a battery charger on the car while you do this.
Sharkey is online now   Reply With Quote
The Following User Says Thank You to Sharkey For This Useful Post:
blackstar (03-19-2017)
Old 03-19-2017, 09:45 AM   #3
Or if you know someone with a good scan tool. Certain ones like the Mac mentor, snap on solus, tech 2 or ones of higher caliber they can do it as well
Omiotek is offline   Reply With Quote
The Following User Says Thank You to Omiotek For This Useful Post:
Old 03-19-2017, 06:23 PM   #4
I tried this but the light didn't go off. What I did is I connected the old module and turned the car on. While it was running I disconnected the old module and I left the cable unplugged, my car turns on and off but my steering is still hard. I am assuming that cable needs to be connected to the module so the steering can work properly? But if I connect it the security light will come back on and the car won't turn on.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
