Fail!! tried installing leds in hvac. please help
Old 10-27-2010, 09:33 PM
kento19's Avatar
after i thought i had all the bulbs in the hvac controls replaced with leds, i hooked it back up and not only will they not light up, but all the lights in the gauges wont either. this makes it very difficult to see my speed at night. Can somebody tell me what i have done wrong. i was hoping it was just a fuse but i dont think it is.
Old 10-27-2010, 09:34 PM
AWD > FWD
TommyP's Avatar
did you try the fuse? Cuz I think they're all on the same fuse. I could be wrong though.
Old 10-27-2010, 09:35 PM
F_Imports_09tc's Avatar
My guess is fuse
Old 10-27-2010, 09:38 PM
Perfect.disguise's Avatar
Fuse
EvilFusion's Avatar
fuse or dimmer <-- hey you never know lol
Old 10-27-2010, 09:39 PM
corn gas ftw....
ssblackstealth's Avatar
this^^^^
Old 10-27-2010, 09:41 PM
kento19's Avatar
what fuse? i checked the climate control/cluster fuse and the interior lights fuse. which fuse should i check?
Old 10-27-2010, 09:44 PM
superbrowndude's Avatar
Did you,Did you really ?
Old 10-27-2010, 09:58 PM
wollis1's Avatar
you said u were using leds.... u make sure the positive and negatives were connected properly and not in reverse? it matters with led's
Old 10-27-2010, 10:16 PM
EvilFusion's Avatar
thiers 2 fuses for cluster @ floor console fuse block.. Fuse 7 is cluster and fuse 16 is climate control system/cluster have you checked both...
Old 10-28-2010, 03:38 AM
EmperorJJ1's Avatar
did u also use resistors and such? or just full throttle power
Old 10-28-2010, 07:05 AM
kento19's Avatar
no i didnt use resistors. before everybody posts on how much of an idiot i am, can somebody at least explain to me what a resistor is
Old 10-28-2010, 07:37 AM
scottydoh's Avatar
The resistor drops the voltage to one that the led can handle...the board is getting 12v and the led's most likely run at like 3.5v...unless of course you bought 12v led's then none of this matters
Old 10-28-2010, 08:40 AM
kento19's Avatar
so without a resistor the led wont work? they aren't 12volt. where do i get resistors?
Old 10-28-2010, 08:42 AM
Radio Shack or a hobby store
Old 10-28-2010, 11:56 AM
EvilFusion's Avatar
First figure out what rating your LEDS are rated for.. There are many different resistors you can buy all with different amount of resistance
Old 10-28-2010, 12:12 PM
EmperorJJ1's Avatar
there is no such thing as a 12v led... if what ur putting on there is just the led and prongs then they need resistors. a 12v led is just an led that already has the resistor but it would have wires and stuff
lastly your leds are going to need to be small and wide angle. most are directional and trust me it makes the hvac controls look like ****. guess its better then nothing thou
Old 10-28-2010, 01:11 PM
kento19's Avatar
Right now I just stuck two already wired walmart LEDs in there and put it in place to make it visible. I checked every fuse in the floor box(even the non related ones) and none are gone. I'm guessing me using lights without resistors ruined my cluster lights as well. Can anybody else figure out why the cluster lights wouldn't work?
Old 10-28-2010, 01:14 PM
ecot3c inside's Avatar
no, no it doesn't.
Old 10-28-2010, 04:41 PM
kento19's Avatar
still trying to figure this out. is it possible that the hvac is the middle of a circuit for all interior lights. the steering wheel control buttons dont light up either. if the hvac control system is completely removed will that prevent the cluster from lighting up?
Old 10-28-2010, 04:43 PM
Nacademus's Avatar
If you put them in backwards, they stop current.
Originally Posted by moranjames89
no, no it doesn't.
Yes it does...
wtf?
Old 10-28-2010, 04:45 PM
09xfebalt's Avatar
I can BS I used 12 leds that DO NOT have any resitor can take pics if you like.
Old 10-28-2010, 04:49 PM
kento19's Avatar
so how can i fix this. i took all the bulbs out completely and it did nothing.
Old 10-28-2010, 09:59 PM
EmperorJJ1's Avatar
the hvac controls dont need to be in at all for any lights to work. on both fuse panels yank all the fuses and visually check to see if they are ok. and make sure the car is off with the keys out of the ignition
Old 10-28-2010, 10:25 PM
EmperorJJ1's Avatar
show me what? yes its possible to use leds without resistors in an application that uses less voltage or multiple leds wired properly. but what does that have to do with my statement that there is no such thing as a 12v led? to be honest im probably a liar. i bet there is an led that takes 12v but its not going to be a standard looking led and nothing u can just pick up at radioshack or walmart or anything like that. no offence to the OP but someone looking at a real 12v led isnt going to be asking that question. im just saying
Quick Reply: Fail!! tried installing leds in hvac. please help
