Ignition to radio wire...
its the wire so when the key turns over the radio turns on... any idea which one it is?
i tired the use and it just gave me problems and i tired to look for the wire but could not find it
its for my gauges i have tired the fuse but all i get is issues so all fuse hook ups are out...
you have a pic? or can you take one and post it tomorrow or something....
i have a completely 150% base model ok. all u need is an add-a-circuit.
this thing
next you locate where the sunroof fuse SHOULD be.
stick into the spot where the sunroof fuse should have been.
THAT IS YOUR NEW RAP ACCESSORY WIRE!!
nitrous, boost, and wideband
where can i get one and explain again how it works dont understand a little lost...
#38
straight line from battery to trigger switch would be bad ass
you have aftermarket radio?
Last edited by silver187666; 12-14-2009 at 01:02 AM. Reason: Automerged Doublepost
#39
thats what i had in mind at first but i dont really want a switch i have to many already (nitrous on, bottle heater, sound system, nitrous shifter switch) all are hidden so you cant see them but still...
no i have a stock radio but plan on getting touch screen soon...
#40
hold out until you do, try to see if you can run the wire you want off the acc, it should work just like your radio does for up to 15 mins after the cars shut off
#48
Omg not to the thread starter but this is the dumbest ******* thread i've ever read. Just take the remote wire coming out the back of your radio and run that bitch straight to your amp...the remote wire is blue or blue with a white stripe...mine was solid blue
#49
well brickloaf in stead of being a dick you could of simply said what the remote wire looked like. some of us are not familiar with gm wire colors
#50
Not being a dick I just can't believe it took 3 pages to say the remote wire is blue and I know there are like 5 people that have already posted that definately knew this
