noob wideband question..
I want to hook up my wideband but idk where to qire the white wire from the wideband. I read a how to for an 06 cobalt and he put it with a purple with white stripe wire by the pcm. Others I seen on here dont mention that wire. It is for analog output and idk what that is 😒
I'm assuming you have the UEGO AEM wideband? I just installed it in my car a while ago. Unless you're logging you can ignore the white and blue wires. They are for logging with HPT. I'm not sure if Trifecta uses it or not but from the previous posts it doesn't look like it. All you should have left is the black and red wires. I tapped a fuse on the passenger side fuse box and grounded to a bolt in the same area. If you do this I recommend extending all the wires. It's a stretch to get to the box for power and while tuning with the signal wires the HPT interface sits on the ground. If you've got any more specific questions I can get you pics tonight (Assuming it is the UEGO gauge).
n20saturn
09-30-2015 12:26 AM
shawnsseries
09-10-2015 08:29 PM
