noob wideband question..
Old 04-17-2014, 01:38 AM
Crav3's Avatar
I want to hook up my wideband but idk where to qire the white wire from the wideband. I read a how to for an 06 cobalt and he put it with a purple with white stripe wire by the pcm. Others I seen on here dont mention that wire. It is for analog output and idk what that is 😒
Old 04-17-2014, 01:58 AM
ThexGovenor's Avatar
Well it depends on the wideband. but you need a hot wire and a ground. You can use "add a fuse" to get the hot wire. the ground can be wired somewhere on the block. Other than that you should be fine. what model wideband?
Old 04-17-2014, 02:06 AM
Crav3's Avatar
Its an aem wideband, and both how tos I saw used the aem
Old 04-17-2014, 02:07 AM
ok, so do you know which is the hot wire and which is the ground? and are you hooking up to HP tuners or a gauge?
Old 04-17-2014, 02:43 AM
Crav3's Avatar
Well by hot wire im thinking you mean the red power wire, and ground wpuld be black. And no hpt im gonna get trifecta tuned
Old 04-17-2014, 01:03 PM
Well the analog output will wire into the tuning interface. the power wire you can hook up to an add fuse and the ground to the block. Someone else might be able to explain better
Old 04-18-2014, 02:11 AM
Crav3's Avatar
Yea thats sorta what the aem instructions say. How would I go about doing it with trifecta? Lol
Old 04-19-2014, 12:29 AM
southal cobalt's Avatar
it wont hook to trifecta. get hpt tuned if you want an exact afr
Old 04-21-2014, 02:53 AM
Crav3's Avatar
So I dont need it for trifecta? .. so I bought it for nothing? I thought I needed it to log. And I will do hpt when I get forged rods and pistons, smaller pulley and bigger injectors
Old 04-21-2014, 03:10 AM
Twoozofjuice's Avatar
Yes you need it to get tuned but you will have to be telling vince what the afr is and such. With hptuners you can connect it directly into hpt and have it read the info
Old 04-21-2014, 11:17 AM
Crav3's Avatar
Oh alright go for it. So just wrote down what it is everytime. So for now I just ignore that wire, is that right?
Old 04-21-2014, 12:02 PM
Well not really ignore it. I'd make extension for it so that you dont have to take everything apart again when you get hptuned
Old 04-22-2014, 02:40 AM
Crav3's Avatar
Good idea. Thanks alot man.
Old 04-22-2014, 09:58 AM
soaxin's Avatar
I tapped the power and ground off the stock boost gauge.
Old 04-22-2014, 10:03 AM
WVU_SS's Avatar
I'm assuming you have the UEGO AEM wideband? I just installed it in my car a while ago. Unless you're logging you can ignore the white and blue wires. They are for logging with HPT. I'm not sure if Trifecta uses it or not but from the previous posts it doesn't look like it. All you should have left is the black and red wires. I tapped a fuse on the passenger side fuse box and grounded to a bolt in the same area. If you do this I recommend extending all the wires. It's a stretch to get to the box for power and while tuning with the signal wires the HPT interface sits on the ground. If you've got any more specific questions I can get you pics tonight (Assuming it is the UEGO gauge).
Old 04-26-2014, 12:02 AM
Crav3's Avatar
Yes its the uego a wideband. Pictures would be great since I haven't got around to installing it. Gotta get the bung welded in for the sensor
DarrenGC
12-24-2021 01:55 PM
n20saturn
09-30-2015 12:26 AM
xxenjoi11
09-29-2015 12:36 PM
Gabriel94
09-17-2015 08:18 PM
shawnsseries
09-10-2015 08:29 PM
Quick Reply: noob wideband question..
