so i set my gains for the final time
Old 10-11-2008, 02:19 PM
creedin's Avatar
after running new rcas and taping off my power cables, i have touched my amplifier for the last time
but in my method of doing the setting of the gain, i did 1500 (watts rms) x 2 to get 3000 and did the square root of that. so about 54.7 volts (ive found that value two places now, so im pretty sure it's okay) but for where its easiest to set my bass control, straight 90 so i get the same everytime) i could get it at about 58-60 volts, no matter how i adjusted the gain, so my question is is that going to be okay at +4-6 volts?
also i tested it at about 30/34 on my volume and it was 60 and at about 26, my normal volume, it was at about 59.5 or so... should i be okay?
all was tested with a 60 hz tone
Old 10-11-2008, 02:25 PM
Cougarguy's Avatar
i like your style dude, i personally recommend an oscilliscope. watch the sine waves, when they flatten then distortion is occuring. flat spots are damage in due time. make it perfectly round and complete.
Old 10-11-2008, 02:28 PM
creedin's Avatar
but arent oscopes expensive? thats why i didnt get it, i looked and theyre like 1.5 billion dollars
Old 10-11-2008, 02:56 PM
Cougarguy's Avatar
lol...no idea i used lincoln techs and then my crap ass MA audio HK series started smokin
Old 10-11-2008, 11:08 PM
creedin's Avatar
anyone else
Old 10-11-2008, 11:33 PM
EmperorJJ1's Avatar
yes they are
Old 10-12-2008, 03:25 AM
raptors_67's Avatar
That's just one aspect of using a scope to set gains and a pretty small part of what they are useful for but certainly a huge help. It's always assumed that by finding peak amplitude before clip nets peak power but is not always the case.
Why are you taking the square root of supposed combined wattage of 3000 to obtain an RMS voltage? Just curious where you heard this formula for finding RMS volts. Did you use a multimeter or something?
Old 10-12-2008, 05:14 AM
EmperorJJ1's Avatar
sry guys went to a local "comp" in what ended up to be basically mexico and it was pretty ghetto so i was useless when i came back
Setting your gains with a DMM sorta half works and sorta doesn't. I haven't read up on the correct formula because honestly i've never done it. I would think rms watts/ amp draw= VAC but like i said i don't know. Now the reason people set the gain with a DMM is because it theoretically would allow you to play a sine wave without clipping. Now the only problem with that theory is a sub is a variable load meaning the resistance changes with different frequencies and with the heat of the coil. Hence why competitors run their stuff at .5 or .35 ohms most of the time it rises to 1 or 2 ohms in those competitor situations and seeing 10+ ohms on a street setup isn't surprising. So since the resistance is so variable setting it with a dmm doesn't allow you to get the max unclipped volume. You can often have a higher gain setting on music and be fine.
85% of blown equipment is either user error, install error ect ect
the other 15% is actual manufacture error
Old 10-12-2008, 10:20 AM
creedin's Avatar
i read on two different sites that a good way to figure out the proper voltage is from doing that... and then i used a multimeter to read how much was going to it
Old 10-14-2008, 02:16 AM
raptors_67's Avatar
what kind of multimeter?
Old 10-14-2008, 02:18 AM
EmperorJJ1's Avatar
lol what kind of multimeter? as long as it works its all gravy
Old 10-14-2008, 04:14 AM
Spun's Avatar
Oh I beg tio differ.
The first one I ever bought did not have an audiable tone for the Continuity test
It just gave you the readings. This was not cool, makes alot of things a pain in the ass.
Just make sure it has digital display, and "Buzz" feature.
Auto power off is a good feature to have too.
Old 10-14-2008, 06:33 AM
EmperorJJ1's Avatar
i agree there's nicer ones out there but its not really "necessary"
I have one of the nicer craftsman ones...
Old 10-14-2008, 11:41 AM
raptors_67's Avatar
RMS meters work a little better when trying to approximate output like the OP is.
Old 10-14-2008, 11:09 PM
Spun's Avatar
I guess my post was a little deceiving, I wasn't really disagreeing with you but trying to warn about the non buzzing multi meters.
I actually have a craftsman too, I'm sure not as high tech as yours, but it does what i need it to do. But I betcha my sodering iron is better than yours (I'm so just kidding).
Any multimeter will do what you need from it, should only cost you $30.00 to $50.00 for a decent one. I find that if you go to with the really cheap ones ($19.99 at Walmart) there not accurate, not even close. Just buy the cheaper line from a good name brand, like craftsman, ect.
I find the RMS ones a little more complicated, I think just a basic one would better suite the OP, better to work your way up to something like that rather than dive right into it.
Old 10-15-2008, 01:38 AM
EmperorJJ1's Avatar
**** the RMS bull ****. my add doesnt keep up with that speed
lol jk but hey spun u didnt respond to my question about the Piaas in the hid/halogen thread
Sry back on topic. Um at the shop we have every meter known to man and i honestly like my craftsman one the best bc its the most user friendly (plus it was on sale along with my drill at the time) but like i said we have the cheapo ones for 2.50 an rms meter an analog meter some craftsman ones ect ect and everyone at the shop agrees craftsman ftw
Oh and i actually dont own a soldering iron so you have me beat. but my boss has not one but 2 crazy ass ones that **** **** up literally. That **** don't play games
Old 10-15-2008, 01:43 AM
blissmaster13's Avatar
Holy crap!!! I have nothing helpful to contribute to this thread, but you guys are speaking a foreign language to me. I just thought it was funny. I was trying to read the first post and was like.............WHAT!!! Just goes to show that each person has their trade or hobby. Anyway, continue as needed.
Old 10-15-2008, 02:15 AM
EmperorJJ1's Avatar
lol if you want me to decode it for you i can
Bluelightning
11-11-2015 02:41 PM
InfraRedline
Drag Racing
35
09-29-2015 02:09 PM
Dustonian131
09-23-2015 08:03 PM
Green
09-13-2015 01:30 AM
jcalvin1126
09-11-2015 10:24 AM
Quick Reply: so i set my gains for the final time
