Reduced Engine Power & Battery Light On
Old 02-12-2017, 06:42 PM
Core415's Avatar
Hey Everyone,
My 2005 cobalt has been giving me some issues lately. My wife was driving it one day and all of a sudden the gauges started to go crazy. She was actually able to get the car home and once she did the car completely died. After looking at the car I noticed 6 specific things that happen every time I try to start the car. first being that the battery light comes on, the LCD display states "Reduced Engine Power", the gauges go nuts, my radio doesn't work at all, and I hear a loud rapid clicking noise when I turn the ignition key which I'm assuming is the start reply.
I went out and got a new battery thinking that it would fix the problem but as you can guess it didn't. I was thinking it might be the alternator but I'm having seconds thought on that because even if it was the alternator was bad won't the radio still work. One more thing, I am able to jump the car and as long as it is hooked up to the other car it runs fine. The radio still doesn't work but it will run.
Old 02-12-2017, 07:57 PM
cluelessk's Avatar
Check fuses and grounds. Your serpentine belt still there? Terminals clean on the battery? Have you tried fully disconnecting the battery for a while to reset the ECU?
Old 02-12-2017, 08:12 PM
Core415's Avatar
Thank you for your response. All the the wiring is sheathed and I won't even know where to located all of them. I have disconnected and left it disconnect for 24 hours with still no luck.
Old 02-13-2017, 03:44 AM
blu3_v1p3r's Avatar
If it says Reduced Engine Power there should be Check Engine Light as well. Get that scanned. Other then that check fuses, grounds, check the terminals on the starter to make sure wires are still tight. Are you 100% that the battery is good?
Also disconnect the battery and then disconnect the ECU for a little bit, then reconnect and try again.
Old 02-13-2017, 02:48 PM
Core415's Avatar
at first i thought it was the battery at first so i bought a new one.
Old 03-16-2020, 06:04 PM
06cobaltss/sc99's Avatar
Did u ever find out what was causing this problem to happen?
Old 03-17-2020, 11:10 AM
Rattlesnake Race Shop
USMCFieldMP's Avatar
They haven't visited this site since 03-23-2017 at 02:59 PM.
What's your problem and what are the symptoms?
Old 03-17-2020, 12:09 PM
the car is giving me engine power reduced and showing the battery light every time I turn it over I’ve already replaced the battery and the alternator and tried holding the ground and power wires together to reset the car
