RPD boost stays at 0psi
Hey guys so i just joined and I just picked up an 09 cobalt ss/tc used with just under 70k from a dealership but my only complaint is that the boost reading on the rpd just stays at 0psi no matter how I drive it. No CEL or codes. I haven't found any info on what it could be so any help is appreciated as I just got this car and am learning as I go. Thanks!
I scanned the car with my scan tool and no pending or history codes. Ive taken it to WOT and the RPD boost display just stays at zero. I checked all the vacuum and boost hose connections but everything seems to be connected. You say a bad map sensor would do that but wouldn't that set the CEL with a code? Im really stumped. Thanks guys.
No, find someone around you who has HPtuners or buy a copy of HPTuners (you'll only need the standard) and have them scan the car while operating. I'm trying to recall when a local I tuned had a bad map sensor if it threw a code or not.
Ford dealer or not if you just bought it you should be able to take it back and have them fix it. At least where i live all cars used have at least 3 months of warranty. Unless its from a hole in the wall dealer that just sells used cars. I bought mine from a carmax and the mass air went out a few weeks after and they fixed it for free.
They said they couldn't do anything because they are ford. Typical right? Anyways about the RPD, it displays everything else except boost. Stays zero. What can I do other than take it back? What causes this?
