RPD install in sedan. Second ever done?
Old 11-23-2015, 04:36 PM
firehawk618's Avatar
I am installing an RPD in my sedan and thought I should make a fresh new thread for other's reference.
I picked up a used RPD that didn't come with the body side connector.
Here's an old post that lists the part numbers for the female connector, pins, bcm pinout etc. VERY GOOD INFO!
https://www.cobaltss.net/forums/08-1...5/#post2893639
To make it fit my car I picked up a ZZP coupe pillar. I have my sedan pillar + coupe pillar at a guys place who is grafting the two together. To me this is the hardest part because I do not have fabrication skills.
To wire it all in I am going to go with the way the factory did it. There are easier ways that would likely work just fine but I am going to go ahead and do it like the factory does.
To do that I am going to be running 6 wires to the BCM. To follow the factory way of doing it I must intercept the GMLAN at the BCM. It will go BCM>RPD>*will fill this in after looking at a schematic* but basically the GMLAN is daisy chained. That means if you unplug a device in that chain then nothing else will work. That's how they built it.
I did a bench test and just ran the in+out together to the OBDii port and it worked fine. This would be the easiest place to tap in for the info it needs to work. The other 3 wires are just 12v constant, 12v switched and ground.
Here's a picture of my completed harness. I just need to put it in some sheathing and wire it into my BCM.
ALL the information you need to buy the right connectors + wire one of these in properly is in this thread:
https://www.cobaltss.net/forums/08-1...er-rpd-133625/
Here's an older thread about a guy who built his own pillar:
https://www.cobaltss.net/forums/appe...-sedan-272472/
I put the coupe pillar on my sedan and sure enough it's shorter and the part that goes on the headliner is a slightly different shape.
When I'm all done I will have the RPD + factory boost gauge in the pillar.
In my cluster pod I will have an AEM wideband + Interceptor.
Old 11-23-2015, 09:01 PM
T-fog's Avatar
Not sure if this is an informative or progress thread lol either way I'm in
Old 11-23-2015, 09:07 PM
Well, it's got info and progress so I guess you could say it's both.
Old 11-25-2015, 08:50 PM
AngelTiger82's Avatar
I wish there was a step by step how to im a little discouraged. I have one sitting in my garage waiting to be installed in an 09 lnf. Im about to hunt down an entire wire harness I just have the pigtail part of the dash harness where it connects.
Old 11-25-2015, 08:54 PM
What do you want to know. All info is in the links.
Ground, constant power, switched power and lan wires. That's it.
*disregard. Re-read your post.
Old 11-30-2015, 10:33 PM
And done!
Pics tomorrow.
Old 11-30-2015, 10:36 PM
Looks good man good job
Old 11-30-2015, 10:49 PM
Thanks! I really like it!
I can see what others have said though, after the honeymoon period wears off i'll find a favorite screen and it will just sit there forever lol.
I have a feeling it's going to be speed on the main screen + air temp/engine temp/fuel pressure
Side note: I have read several people saying the RPD showing no knock but an interceptor or hp tuners showing knock. I was getting lots of false knock today when barely touching the throttle until I installed this then I couldn't get it to knock at all!
Go figure. I have to wonder if the RPD filters out the false burst knock where hptuners / interceptor does not.
I will be increasing low rpm timing to induce real knock and see if the RPD registers it, then go back to normal timing and see if the false knock shows up when it does on the interceptor.
Old 11-30-2015, 11:49 PM
Update with whatever you find out for mine I found out I got a bad batch of gas haven't seen it knock in a few days
Old 12-01-2015, 12:39 AM
I will for sure.
Old 12-01-2015, 11:16 AM
YelloEye's Avatar
Wow. I see why people like that gauge. That's pretty nifty.
Old 12-01-2015, 12:12 PM
You had never seen one in action?
Well today after the cold start I saw a little bit of kr on first only
Old 12-01-2015, 02:45 PM
alerosaint's Avatar
Looks good firehawk....You coming to Griotts this Saturday?
Old 12-01-2015, 09:34 PM
I have been watching the interceptor for knock. I have it set to alert on knock. The only time I could trigger any was just now in my driveway. Car had cooled down a tad. Fired it up and just whack the throttle in neutral and it consistently would trigger knock on the Interceptor but never on the RPD. I am 100% sure there's no possible way for any real knock.
I would smack the pedal as fast as I could. I mean so fast that the engine would barely blip up in rpm's and like clockwork I would get alarms on the Interceptor and am certain it would log with HP tuners if I were logging.
I'm really starting to think the RPD doesn't show burst knock but will only display real knock. If only it would flash the whole screen or something when knocking to alert the driver. I have yet to see any knock on it so maybe it does. I do not know.
My next test will be to add a bunch of timing to induce knock and see what happens.
EDIT: I'm going to stop worrying about knock soon as long as it doesn't happen under load.
No I am not, I have to work. Thanks for the props!
Old 12-01-2015, 10:21 PM
Yeah same here lol no point if it just happens like that
Old 12-02-2015, 01:03 AM
I have a theory.
A few days ago it was alarming me on the interceptor a lot.
I could go miles with nothing then one aggressive stab of the throttle *even if only for a second* would trigger it.
After it was initially triggered it seemed a hair's input on the throttle would trigger it again and again and again for a period of time.
I could trigger it by pressing 1/4" on the throttle while cruising. Hold it in that spot then it would just go away after a second or two.
I think once the ECU thinks there's going to be knock *burst knock* it then stays super sensitive to burst knock for a predetermined period of time........
I have never seen a single degree of timing being pulled on my logs during these knock events and I have never seen a bit of knock on a wot run once it gets past the initial tip in knock if it even does that knock.
Old 12-02-2015, 07:43 AM
Omiotek's Avatar
Theres usually a couple degrees of kock you will see as you get into wode open throttle. Its pretry normal and its probably not actual knock. These cars have noisey engines. What you dont want to see is knock at wide open throttle
firehawk618 (12-02-2015)
Old 12-02-2015, 11:58 AM
YelloEye's Avatar
Checked over on the HPTuners forum? There's a couple threads there about false tip in knock on the LNF.
Old 12-02-2015, 05:19 PM
I think i've read every thread regarding LNF and knock, false knock, knock retard and burst knock lol.
Just the way our PCM's are.
Old 12-02-2015, 10:05 PM
Done and done!
*The RPD isn't nearly as washed out as my camera makes it look.
Video:
Old 12-03-2015, 12:34 PM
YelloEye's Avatar
I think you're right, and GM decided to detune the sensitivity of the gauge so that customers didn't bring it in and freak out.
Old 12-03-2015, 06:47 PM
I think it only shows real knock instead of the others showing anticipated knock.
I wish HPT had more tables opened for us.
Old 12-03-2015, 09:25 PM
T-fog's Avatar
Looks good man, Now I want one lol
Old 12-04-2015, 12:01 AM
YelloEye's Avatar
One can dream.
Quick Reply: RPD install in sedan. Second ever done?
