Signal Wire to turn on Amp on 06
Hi,
Does anyone know what wire to use to switch on an after market amp on an 06 base model LS 2 Dr. Coupe with stock radio? I see the pinout posting but it says "radio on signal" is Pink. I do not have any pink wire going to the radio. Thanks in advance for your help.
Rick
Rick
Originally Posted by Cory'sCobalt
Hi,
Rick
Rick
What Head Units Fit?
Hi,
I am checking out Best Buy and Circuit Cities fit guide for the 06 Cobalt 2dr and both sights say they have nothing that fits. Do either of these stores sell a head unit that fits with the installation kit and harness. It appears to me from other installs that I have done, that this is not much different in size.
Thanks
Rick
Thanks
Rick
Hi,
Thanks
Rick
Thanks
Rick
You do not need to buy a $120 wiring harness to put an aftermarket radio in the Cobalt. I'm not sure which harness you need, but I think it's been posted here somewhere. I chose to splice into my wires, as I only needed the constant power wire and ground. I tried to get the wiring harness from Best Buy, but they gave me the wrong one. I finally said, "F*** it," and just hard wired it. You don't have to relocate your factory stereo. You won't lose your chimes, and everything works perfect. Don't listen to the idiots that try to talk you in to more than you need. Best Buy does carry the dash kit, as that's where I got mine. If I remember correctly, the dash kit is the same as the newer Malibu and Equinox.
