Question about Wiring Harness
Old 11-22-2011, 09:16 AM
murphxrockstar's Avatar
Okay, so I'm working on installing two 12' Kenwood subs, a 2000w Power Akoustik Amp, an Aftermarket head unit into my 08 Cobalt Sport. So I went to walmart, and picked up the wiring harness that said for ALL GMC 1992+. So I snagged that one, as that was the only one that made any bit of sense. I get back to the house, take of my stock head unit, and the harness doesn't fit. We were gonna rewire the car, but I didn't want to do that.
So I called best buy and they said due to the fact that I have the pioneer upgrade, it has a 250w built in amp to the stock head unit. They said that I'd need a special wiring harness to avoid the system burning out that amp. They told me it'd run about $150.
I'm a bit of a stereo noob, therefore I'm asking you all is this correct or is there another option?
Thanks for all the help.
Old 11-23-2011, 03:17 AM
EmperorJJ1's Avatar
is that correct. technically yes it is but they do make a normal harness you can use if you wanted to. read the FAQ for the difference. also walmart harnesses and kits stopped being correct in about 95ish
Old 11-29-2011, 04:50 PM
Where can I find this harness & will it work just as good?
Old 11-30-2011, 12:08 AM
EmperorJJ1's Avatar
will it work as good? no but it would work.
the expensive harness is best for the pionner setup retains onstar and retains chimes
the cheap harness is slighly harder to install, no onstar, no chimes, and while not best for the pionner setup it works
Old 11-30-2011, 11:39 AM
chitala383's Avatar
I used the cheaper harness and I'm very satisfied with it. I don't care about on star and the door chimes annoyed me so i was happy to get rid of those. It was pretty simple to install as well. Though I've probably done about 20 head unit installs over the years so i had a pretty good idea of what I'm doing. Haha
Old 11-30-2011, 11:42 AM
1LowLS's Avatar
The harness I used is for a 07 ion/vue.No chimes but I 'didnt mind and was only like 15 bux.
Tupp
2.2L LAP Performance Tech
01-02-2016 12:04 PM
ineedacobaltss
11-07-2015 02:25 PM
brandon04
10-21-2015 07:04 AM
dennis69
10-20-2015 07:39 AM
jmelton327
09-26-2015 10:04 PM
Quick Reply: Question about Wiring Harness
