speaker cutting in and out - Cobalt SS Network
Thread Tools Search this Thread
Old 05-12-2011, 07:39 PM   #1
My driver front speaker has started this spell lately where it will randomly work sometimes, and other times have absolutely no sound at all. It doesnt have any of the signs of going bad like buzzing, rattling, etc. I've also noticed that when it does work, the clicking sound for my turn signals works. But when the speaker is not working, neither is the turn signal sound, but the signals still flash inside and out. I was wondering if anyone had run into this issue before and what it could possibly be?
TwistedLithium is offline   Reply With Quote
Old 05-12-2011, 10:14 PM   #2
The signal sound on newer cars runs through the stereo so im guessing that its just a side effect.
I'd set the stereo to only that speaker using fade/bal and take apart the door panel, start wiggling the connections, hopefully its just gotten loose at the speaker from slamming the door. Otherwise you likely have a pinched wire somewhere. I doubt it could come loose at the stereo but ive never seen the connections on these so donno for sure.
dougsmiley is offline   Reply With Quote
Old 05-13-2011, 03:27 AM   #3
EmperorJJ1's Avatar
Images: 315
id bet its a blown speaker. ur chimes come from the front drivers speaker so if its out then no chimes
EmperorJJ1 is offline   Reply With Quote
Old 05-13-2011, 10:59 AM   #4
Well if it was blown itd be out all the time or it would crackle and buzz when it did work. It works perfect, it just goes in and out a lot
Old 05-13-2011, 02:17 PM   #5
Images: 4
Check the wires, the harness takes a lot of abuse where it passes from the door to the frame - it gets flexed every time you open / close the door.
PITA to repair with the wires running through that rubber boot
DaBuzzard is offline   Reply With Quote
Old 05-13-2011, 03:01 PM   #6
either the wires are pinched in the boot in your door. or it's possble the headunit's power system is going bad. When i was looking at balts I drove an 07 and the radio wasn't working nore were the turn signals making any sound... turns out it was the amp had gone bad. although having sound to ur others makes me think it's broke in the door. reason for it working sometimes is you may close the door and the wires may settle against each other causing them to work, but u may open the door and close it again and they don't settle against each other that time. check the wires in the boot.
N1ckateen is offline   Reply With Quote
Old 05-13-2011, 03:16 PM   #7
Images: 5
more likely the plug is loose, mine did this on the driver side and the one in the back (cant remember which). i had to adjust the female metal tabs in the plug bc they wouldnt connect fully. now i have aftermarket speakers so for better sound quality and no more cutting out randomly
Kolt is offline   Reply With Quote
Old 05-13-2011, 09:27 PM   #8
EmperorJJ1's Avatar
Images: 315
yank the panel and see. theres no standard way a speaker will go out so it doesnt have to make any noises. the tinsil wire could be broken in half or half broken to cut in and out... theres a much bigger chance the speaker is broken then anything else
Old 05-13-2011, 09:47 PM   #9
If it is the plug electrical tape the heck out of it before you put the panel back on so you dont have to go in there again.
Old 05-16-2011, 06:20 PM   #10
Well i pulled the panel today to have a look around. The wiring all seems to be intact and the harnesses have good firm connections. the speaker seems fine, and i even tried turning on the radio and wiggling all wires and connections around a little. it hasnt worked period the last couple days. and i'm starting to get frustrated. its like being deaf in one ear. any other ideas guys? i appreciate all your feedback thus far.
Old 05-16-2011, 08:56 PM   #11
EmperorJJ1's Avatar
Images: 315
take the speaker out and with a 9v battery ouch it to the pos and neg and see if it moves or pops. if it does then the speaker "should" work if not then the speakers toast
Old 05-24-2011, 03:06 PM   #12
Images: 19
I've been having the same problem with the driver side speaker for the past month or so and last night, the turn signal chime finally gave out and the display on the headunit goes blank occasionally. I have a 100% stock, base model, (non-Pioneer) system. I'm thinking that the root of my problems is the headunit...
scottydoh is offline   Reply With Quote
Old 05-24-2011, 08:38 PM   #13
Quote:
x2
If it does end up moving you're going to have to do a continuity check with a meter by removing the radio and setting the meter to continuity and putting one probe to one side of the connector that plugs into the speaker and one side into the harness pin with the corresponding wire color that you're probing on the speaker connector. If it beeps you're fine if it doesn't you've got a break in the wire or another issue somewhere along the run, in which case you'd just solder in a new wire to the existing wire coming out of the back of the headunit and run it to the speaker....if THAT didn't correct the issue then you might just have a bad channel on your radio or amplifier...good luck mang!
c4w18 is offline   Reply With Quote
Old 05-24-2011, 11:25 PM   #14
EmperorJJ1's Avatar
Images: 315
Quote:
does the music work on the speaker but not the chimes? also when the display gives out does the music/chimes stay or no?
Old 05-25-2011, 05:01 PM   #15
Images: 19
music does not work on that one speaker either, and when the display goes, the music keeps playing and all functions of the radio still work...you just can't see anything. And when I got in my car this morning, everything magically worked again...odd
Old 05-25-2011, 11:12 PM   #16
i fixed it over the internets using remote speaker repair technology. That will be $150 labor please and thank you.
Old 05-25-2011, 11:22 PM   #17
EmperorJJ1's Avatar
Images: 315
im guessing blown speaker and broken display on the HU
Old 05-27-2011, 08:36 AM   #18
Images: 19
Its odd that both would go at the same time...oh well, I guess I can live with it for now, I'll change things later on down the road.
Old 05-28-2011, 02:29 AM   #19
EmperorJJ1's Avatar
Images: 315
thats true. if anything id check out the speaker change that and possibly live with the half messed up display. You can also try taking off the "face" of the stock radio (it is removable but its screwed and has clips and such) and putting some flux wash or something on the connection to verify thats not the problem. Its a long shot and id guess at best 20% chance of fixing it but hey if you have a few hours and 5 bucks it cant hurt
Old 09-09-2011, 06:11 PM   #20
Images: 3
I've been getting the samething with my drivers side.
I have aftermarket speakers. Stock HU.
bbrewbaker is offline   Reply With Quote
Old 11-29-2011, 03:37 PM   #21
Left Front Speaker intermittent and no signal sound
I have the exact same problem as you. Intermittent left front speaker. No crackling, no buzzing....either perfect, or nothing. I have moved the wire boot on the door all around. If it were a wire problem, it would have cut in/out, or crackled or something. I'm thinking it is in the sound system, and must have something to do with the circuitry that makes the turn signal noise. I'm thinking I could have a nice aftermarket stereo put in for the price of a diagnostic from the dealership. It drives me nuts though. I'm only about 40 miles north of you. Maybe it's an Indiana Cobalt thing?
Let me know if you find out what causes this.
Sportsman
Sportsman is offline   Reply With Quote
Old 11-29-2011, 11:58 PM   #22
EmperorJJ1's Avatar
Images: 315
just fyi the speaker doesnt need to do or not do anything to be broken. so just because u dont hear crackling doesnt rule out the speaker being broken. so even thou it might be a connection or amp or hu issue id still check the speaker first because that has the highest probability of failing first
Thread Thread Starter Forum Replies Last Post
For Sale Aftermarket Sale, Take a Look hacadacalopolis Parts 8 10-28-2015 06:09 PM
Appearance: LED Side Marker Lights Jesse How to Guide 57 10-15-2015 11:56 AM
Strut Issue While Lowering Tupp Suspension 5 09-30-2015 08:18 PM
GBRunner24's October FCOTM GBRunner24 Featured Car Showcase 3 09-26-2015 06:44 PM
engine noise coming through one speaker only. brickloaf Electronics, Audio, and Video 19 09-25-2015 09:10 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
