Stereo Help Please
Stereo Help Please
Hey everyone I need a lil help here. I bought and have installed a Pioneer AVIC-N3 DVD/NAV system. I need to connect the stereo to the speed detection circuit, does anybody know where this is or has a website that can help me out? I have a 2005 SS/SC
Amplifier and Radio pinouts, circuit ID's, color codes:
Audio Amp. Connector1
Connector Part Information
• OEM: 12110088
• 24-Way F Micro-Pack 100 Series (GY)
Pin
Wire Color
Circuit No.
Function
A1
L-GN/BK
1794
Left/Rear Subwoofer Speaker (-)
A2
D-BU/WH
346
Left/Rear Subwoofer Speaker (+)
A3
L-BU/BK
115
Right Rear Speaker Signal (-)
A4
D-BU
46
Right Rear Speaker (+)
A5
BN
199
Left Rear Speaker (+)
A6
YE/BK
116
Left Rear Speaker Signal (-)
A7
D-BU
546
Right Rear Low Level Audio Signal
A8
BN/WH
599
Left Rear Low Level Audio Signal
A9
TN
1946
Right Rear Low Level Audio (-)
A10
BN
1999
Left Rear Low Level Audio (-)
A11
D-GN
117
Right Front Speaker Signal (-) (1)
A12
L-GN
200
Right Front Speaker (+) (1)
B1
L-BU/BK
315
Right Subwoofer Speaker (-)
B2
D-GN
1795
Right Subwoofer Speaker (+)
B3
D-GN
1947
Left Front Low Level Audio (-)
B4
L-GN
1948
Right Front Low Level Audio (-)
B5
TN
511
Left Front Low Level Audio Signal
B6
L-GN/WH
512
Right Front Low Level Audio Signal
B7-B10
Not Used
B11
GY
118
Left Front Speaker Signal (-) (1)
B12
TN
201
Left Front Speaker (+) (1)
Audio Amplifier Connector2 (UQ3)
• OEM: 12110626
• 8-Way F Metri-Pack 280 Series (L-GY)
Pin
Wire Color
Circuit No.
Function
A
BK/WH
1051
Signal Ground
B
BK/WH
1051
Signal Ground
C
Not Used
D
L-GN
1011
Remote Radio Control Signal
E
PK
314
Radio On Signal
F
Not Used
G
RD/WH
640
Battery Positive Voltage
H
RD/WH
640
Radio C1
• OEM: 12110206
• Service: See Catalog
• 24-Way F Micro-Pack 100 Series (L-BU)
Pin
Wire Color
Circuit No.
Function
A1
GY
118
Left Front Speaker Signal (-) (1) (U1C)
A1
D-GN
1947
Left Front Low Level Audio (-) (US8)
A2
TN
201
Left Front Speaker (+) (1) (U1C)
A2
TN
511
Left Front Low Level Audio Signal (US8)
A3
L-BU
115
Right Rear Speaker Signal (-) (U1C)
A3
TN
1946
Right Rear Low Level Audio (-) (US8)
A4
D-BU
46
Right Rear Speaker (+) (U1C)
A4
D-BU
546
Right Rear Low Level Audio Signal (US8)
A5
BN
199
Left Rear Speaker (+) (U1C)
A5
BN/WH
599
Left Rear Low Level Audio Signal (US8)
A6
YE
116
Left Rear Speaker Signal (-) (U1C)
A6
BN
1999
Left Rear Low Level Audio (-) (US8)
A7
L-GN
200
Right Front Speaker (+) (1) (U1C)
A7
L-GN/WH
512
Right Front Low Level Audio Signal (US8)
A8
D-GN
117
Right Front Speaker Signal (-) (1) (U1C)
A8
L-GN
1948
Right Front Low Level Audio (-) (US8)
A9
D-BU
1796
Steering Column Radio Control Signal (UK3)
A10
WH/BK
644
10-Volt Reference (US8)
A11
Not Used
A12
BK/WH
1051
Signal Ground
B1
RD/WH
1140
B2
Not Used
B3
L-GN
1011
Remote Radio Control Signal (US8)
B4-B5
Not Used
B6
PK
314
Radio On Signal
B7-B8
Not Used
B9
D-GN
5060
Low Speed GMLAN Serial Data
B10-B12
Not Used
Radio Connector2
• OEM: 12064799
• 12-Way F Micro-Pack 100 Series (BK)
Pin
Wire Color
Circuit No.
Function
A-G
Not Used
H
D-GN/WH
368
Right Audio Signal (+)
J
BN/WH
367
Left Audio Signal (+)
K
TN/WH
372
Audio Common
L
OG/BK
2061
Cellular telephone voice Low Reference (UE1)
M
PK/BK
2062
Cellular Telephone Voice Signal (UE1)
relevant RPO descriptions:
UK3
Control, Steering Wheel, Accessory
UN0
Radio, AM/FM Stereo, Seek/Scan, CD, Auto Tone, Clock, ETR
UQ3
Speaker System, Performance Enhanced Audio
UQ4
Speaker System, 4, Base
US8
Radio, AM/FM Stereo, Seek/Scan, CD, Auto Tone, Clock, ETR, MP3, RDS
U1C
Radio, AM/FM Stereo, Seek/Scan, CD, Clock, ETR
U2K
Digital Audio System S-Band
UE1
Communication System, Vehicle, G.P.S. 1
the radio DOES communicate on the Lowspeed GM-LAN line, it recieves VIN information for TheftLok, illumination dimming inputs, and signal for speed compensated volume.
Some audio functions are available using the steering wheel controls. The steering wheel controls are actually a resistor network which consists of multiple momentary contact switches and a series of resistors. The switches and resistor network is arranged so that each switch has a different resistance value. When a switch is pressed, a voltage drop occurs in the resistor network which produces a specific voltage value unique to the switch selected. These specific voltage values allow the radio to identify which switch has been pressed. The radio responds just as if the corresponding radio front panel button had been pressed.When the radio is ON, the radio supplies approximately 10 volts to the switches on the 10-volt reference circuit. The specific voltage signal from the switch is returned to the radio on the steering wheel controls signal circuit.This may inhibit the use of the redundant control with an aftermarket head unit.
(Gm Service Information 2005 Chevrolet Cobalt)
• OEM: 12110088
Pin
Wire Color
Circuit No.
Function
A1
L-GN/BK
1794
A2
D-BU/WH
346
A3
L-BU/BK
115
A4
D-BU
46
A5
BN
199
A6
YE/BK
116
A7
D-BU
546
A8
BN/WH
599
A9
TN
1946
A10
BN
1999
A11
D-GN
117
A12
L-GN
200
B1
L-BU/BK
315
B2
D-GN
1795
B3
D-GN
1947
B4
L-GN
1948
B5
TN
511
B6
L-GN/WH
512
B7-B10
Not Used
B11
GY
118
B12
TN
201
• OEM: 12110626
Pin
Wire Color
Circuit No.
Function
A
BK/WH
1051
Signal Ground
B
BK/WH
1051
Signal Ground
C
Not Used
D
L-GN
1011
E
PK
314
Radio On Signal
F
Not Used
G
RD/WH
640
H
RD/WH
640
Radio C1
• OEM: 12110206
Pin
Wire Color
Circuit No.
Function
A1
GY
118
A1
D-GN
1947
A2
TN
201
A2
TN
511
A3
L-BU
115
A3
TN
1946
A4
D-BU
46
A4
D-BU
546
A5
BN
199
A5
BN/WH
599
A6
YE
116
A6
BN
1999
A7
L-GN
200
A7
L-GN/WH
512
A8
D-GN
117
A8
L-GN
1948
A9
D-BU
1796
A10
WH/BK
644
A11
Not Used
A12
BK/WH
1051
Signal Ground
B1
RD/WH
1140
B2
Not Used
B3
L-GN
1011
B4-B5
Not Used
B6
PK
314
Radio On Signal
B7-B8
Not Used
B9
D-GN
5060
B10-B12
Not Used
Radio Connector2
• OEM: 12064799
Pin
Wire Color
Circuit No.
Function
A-G
Not Used
H
D-GN/WH
368
J
BN/WH
367
K
TN/WH
372
Audio Common
L
OG/BK
2061
M
PK/BK
2062
UK3
UN0
UQ3
UQ4
US8
U1C
U2K
UE1
Well maybe i should tell the problem first. I got it installed and it works fine, only thing is when I stop my gps arrow on my screen keeps going, till the satelite picks me up and it readjusts me on the screen, over and over again. Also in the unit itself it detects the speed, not as accurate as the speedo, but just in neutral is says i'm doing like 40 km/h, and when i just rev the engine it skyrockets
Originally Posted by DC52NV
dude, wtf? no need to make 3 threads of the same thing in 3 different sections. consider this a warning. moved to the right section.
Originally Posted by sunrise_mj
pioneer navs are usually pretty good about not needing the speed sense wire... i dont have mine hooked up on the n2. just drive it for a few days
Hey thanks for the post, we decided to take that wire off to see what happens, and it works like a charm pretty much now. Only feature that I can't use is the Vehicle Dynamics which tells u the speed and stuff but that's not important lol
soundjunky
08-28-2015 03:24 PM
stealththx
09-03-2005 03:00 AM
