Stock hu, speakers and sub
I want to keep the stock head unit speakers and sub, but I want to upgrade the amp so it hits just a little harder. What amp and loc would best suit this setup?
Disconnect your stock sub from the stock amp and install a small aftermarket amp, something with 100 watt rms or so at 2 or 4 ohm, and that should give it way more bump compare to stock sound. Also if you want more volume and clarity from you tweeters simply swap your stock ones for some infinity reference 1031t at 2 ohms and prepare to be amazed. Tweeter leave with stock amp just swap out the speakers.
