UPDATED General Stereo FAQ - READ THIS!
Old 09-23-2010, 04:08 AM
  #276
EmperorJJ1's Avatar
well not all the wires in the stock harness will be used so thats fine
thats pretty odd thou... go thru and test voltage at the cd player end and make sure ur getting 12-14v on both constant and acc. The only other thing it might be is a blown fuse if the wires touched at some point. otherwise if the fuse on the radio is blown but that shouldn't be the case on a new radio
Old 09-23-2010, 03:24 PM
  #277
Curleh_Mustachio's Avatar
Ok, so after trying out a few fuses, the AMP fuse and power steering fuse seemed to have helped. But now, it doesn't stay on when I turn the accessory switch on (which turns off the radio when I open the driver's door). I'm planning on stopping by ABC Warehouse tomorrow morning and talking the auto guy there.
Old 09-23-2010, 11:14 PM
  #278
EmperorJJ1's Avatar
so its only on when the car is in the on position and not the acc?
does the car have power windows doors or mirrors?
Old 09-23-2010, 11:27 PM
  #279
Nope. Everything's manual. I still haven't found a suitable fuse spot for the cd deck.
Old 09-23-2010, 11:31 PM
  #280
EmperorJJ1's Avatar
if thats the case i think the wiper is ign without rap
acc/rap are only in the vehicles with power stuff.
Old 09-24-2010, 08:30 AM
  #281
Tried to hook it up to a wiper fuse in the floor panel....nothing. But you're definitely helping out Emperor. Getting a lot further thanks to you.
Old 09-25-2010, 03:16 PM
  #282
Rydis's Avatar
not really. the power antenna should work even thou its not a true remote out. The only option other then replacing the radio would be to buy ground loop isolators for the rcas and hope that helps. but thats really a shot in the dark
I just wanted to make sure it wasn't causing harm. In this case..I dont think it is. One last question if you dont mind though
The radio has to use the RCA's, so the harness doesn't use the individual speaker wires (2 for all 4 speakers). However..when I have the harness connected to the RCA of the radio..it is only playing through 2 speakers..not all the speakers..any ideas?
Old 09-25-2010, 10:12 PM
  #283
EmperorJJ1's Avatar
what harness are u using again? it should have 4 rcas or 8 speaker wires
Old 09-25-2010, 10:32 PM
  #284
Rydis's Avatar
the gmos 04. Its the avic d-3 harness (that connects to the stereo) that only has 2 RCA"s though. A Red and White Input, then ouput, rear view camera. THere isn't a way to hook up 4 rcas. It only has a place for 2.
Old 09-26-2010, 01:02 AM
  #285
EmperorJJ1's Avatar
oh thats why its the gmos04 not the gmoslan o4. you might be able to repin it but idk probably not
Old 09-26-2010, 10:44 AM
  #286
Rydis's Avatar
the gmos 04 has 4 rcas for all 4 speakers..its the RCA input for the stereo that only has 2.
As far as I can tell, the only difference between the gmos and gmos 04 is the onstar. The rest of the pins seem to be the same.
Old 09-26-2010, 12:42 PM
  #287
EmperorJJ1's Avatar
oh i c. lol then get some y splitters 1m 2f
Rockford FosgateŽ - RFITY-1M
Old 09-26-2010, 12:49 PM
  #288
Rydis's Avatar
so connecting the gmos rear rca's to the rca's of the headunit will play through the rears and fronts?
Old 09-26-2010, 11:56 PM
  #289
blackbalt sport's Avatar
hard to tell on a module harness like that. id say test the acc and constant and see if both are getting voltage. in most cases a cd player will make that noise when first connected to constant, so if u keep hearing it thats defiantly weird
Ya I don't think I was getting the acc power cuz I jumped it to the fuse box and tapped into a fuse, then it worked fine. Now however I have a lot bigger problems because the car won't start. At first the security light was on every time I tried to start it, then the whole thing went into lockdown and I can't even turn the key or steering wheel or anything!!!!!
Old 09-27-2010, 12:18 AM
  #290
EmperorJJ1's Avatar
ok unplug the harness and the fuse tap and see what happens. If you tapped an acc wire AND hooked it up to the module then it probably pissed off the bcm. hopefully undoing it will fix the problem
Old 09-27-2010, 12:26 AM
  #291
I hooked up the acc wire directly to the head unit i was installing. I undid everything back to stock put its still locked up. Its sitting at the dealer waiting to get checked out. Is there no acc power in the factory harness? its a 06 ss/sc
Old 09-27-2010, 12:34 AM
  #292
EmperorJJ1's Avatar
unless it was a problem with ur security system and it just happened to do it now. the passlock 3 system wont let you do **** if its pissed off. the dealer had my car in lockdown when they were fixing it from the wreck. idk how they fixed it thou all i told them is it drove for 15 seconds after the tow truck dropped it off so figure it out
correct the acc is actually gm lan data.... so it doesnt turn on with a voltage on or off but with a decoded data signal. i did it for less than 24hours for a car show and because i didnt know what i was doing but i hooked up the gm lan to actually acc and the car didn't like it but i was able to drive to the show play the bass and drive home.
Old 09-27-2010, 12:41 AM
  #293
Interesting. Someone told me to unhook the battery before I take the stock hu out so i guess I will try that next time and hopefully it won't lock up.... But ya your rite it could've been coincidence. So that is pretty much the only way to power the aftermarket deck then is do the fuse tap?
Old 09-27-2010, 03:18 AM
  #294
EmperorJJ1's Avatar
yes and no. the module is supposed to decode the gm lan data and make the acc. but in all reality even metra who makes the best ones out there have problems. there's really only so much u can do with the market and given resources. the fusetap is a ghetto way of doing it but in reality if u get something like the "add a fuse" and find a fuse that works its more reliable then the module. hence why im glad i have an 06. in an 06 the only benefit of a module is rcas if u have the pioneer system (but that can be done without the module too) and acc without the fuse tap.
you don't need to unhook the battery before u take the stock hu out that's a load of crap.
Old 10-04-2010, 10:22 AM
  #295
JWhit197's Avatar
Okay guys I read the FAQ but still not quite sure what the guy at car audio was trying to tell me.. I'm installing an Alpine CDA 9887 in an 07 LT I saw two antennas to choose from how do I know which one? Also, he said something about a $95 wiring harness is this post telling me that it is NOT necessary to maintain all factory functions or do I need to get it? And what about an aftermarket single din mounting kit, which one fits the best? Hate to ask any retorical questions I'm just ready to get this **** installed!
Old 11-11-2010, 08:31 PM
  #296
EmperorJJ1's Avatar
u need the crysler antenna adapter.
the wiring harness is going to be 100+ if you want to retain all factory functions. the cheap one u loose chimes onstar and possibly rap depending on the car. you also loose steering wheel controls unless u buy a separate adapter... these can be added regardless of wiring harness
metra dash kits fit and look the best then ai then scoshe (imo... normally scoshe is better then ai but not on the balt kits I've seen) best kits is bullshit b stock
Old 11-23-2010, 09:51 PM
  #297
06'Yellow SS/SC's Avatar
06 ss/sc. Metra harness. Valor hu single din with flip up touchscreen.
Problem is the hu only powers on when the car is started and it doesn't turn off at all, can't control the volume, and it doesn't take cd's.
0.o any idears?
Old 11-23-2010, 09:58 PM
  #298
EmperorJJ1's Avatar
volume control and cd problem is a busted stereo. those units are notorious for those exact problems. as far as the hu powering on only when the car is started that sounds about right. not sure why it wouldnt turn off thou. wiring issue maybe?
Old 11-23-2010, 11:59 PM
  #299
Yeah it was a budget buy. Thanks for the knowledge.
Can you recommend a decent priced unit that is touch screen?
Old 11-24-2010, 12:52 AM
  #300
EmperorJJ1's Avatar
get a double din and you can get a name brand for as much as the valor... look into the pioneer 3200dvd
Quick Reply: UPDATED General Stereo FAQ - READ THIS!
