KMO43 FCOTM + Build Thread
Old 09-26-2015, 01:05 PM
KMO43's Avatar
Car: 2010 Cobalt SS/TC Summit White
Stock Options: XM, Onstar, RPD, Sunroof, Pioneer Sound System
Performance:
-7163 ZFR
-Hahn CAI
-Hahn Catless DP
-Hahn Cat Back Exhaust
-Hahn Charge Pipes
-ZZP Intercooler
-Ported Head, Intake Manifold, Exhaust Manifold & O2 Housing
-Supertech Valesprings Ti Retainers
-ARP Headstuds
-Snow Stg2 Meth Kit 500cc Nozzle
-Southbend Stg4 Plate & Stock Disc
-ZZP Transmission Mounts
-ZZP Engine Mount
-Forge BPV
-Turbosmart Dual Port 23psi Actuator
-LSJ 4.05 Trans
-HP Tuned @ 29ish psi
-Mishimoto Rad
Wheels, Suspension, Brakes:
-Stock TC Wheels Powder Coated Semi Gloss Black
-Nitto NT01s 235/35ZR18
-Eibach Sportline Springs
-ZZP Stainless Steel Brake Hoses
-ZZP Cross Drilled & Slotted Rotors
-Hawk HPS Pads
Interior:
-ZZP RPD Dual Gauge Pod
-AEM Meth Flow Gauge
-AEM Boost Gauge
Future Plans:
-More Fast
A special thanks goes out to: Jon (SylverSS/SC), Nathan112i, Taylor (Infraredline), Jonathan (Soundjunky), Mark (Jrmotosports 88), Sammi from Mr. Detail & Matt from Turbobay
I have both set on red but can choose tons of colors
The beauty
Old 09-26-2015, 01:07 PM
KMO43's Avatar
I'm working on the build part right now I'll be posting it soon!
Old 09-26-2015, 02:11 PM
Nice pictures! Good to finally see your thread bro .
Car is clean af and i envy your build
Old 09-26-2015, 02:16 PM
KMO43's Avatar
STG1
I ordered the car sight unseen and didn’t even test drive it before. I asked for white as my first pick and was only told that I would be happy by my salesman.
The first time I ever saw my car
Car taken home
I was always planning on building the car origanally I was looking for around 300hp I dynoed stock at 220hp240tq on a mustang. So just aftermy first oil change I installed all my bolt ons CAI, DP, Exhaust, IC, IC Pipes and a terrible PPC tune
First trip with the car to Clagray where I live now
Because I had that terrible tuner I added meth to control the knock. Also during the first winter I added a southbend Stg4 clutch, Fidenza aluminum flyfheel, ZZP mounts, ZZP stainless brake hoses, HP+ pads and 6k HIDs
Wheels up!!
KMO43's Avatar
Stg2
Well I had my Hahn intercooler split on a weld and didn’t notice it right away so it blew up my turbo. I talked to Matt at Turbobay and got hooked up with one of the first K04rs.I had enough with the **** tune so jumped on the HPT team added the ZZP gauge pod switch to a ZZP intercooler with cast endtanks also lowered on Eibach springs
Here’s a log on the K04r spool
As I have terrible luck so driving a buddy home I bottomed out and took out my Intercooler and Rad. 2nd IC of the year
Jon (SylverSS/SC) hooked me up with a Mishimoto rad and I bought a local IC just to get me by
I’ve been told that I have an issue of not sleeping and just staying up late thinking of how to get more power from my setup and I was confused on how that 65mm wheel can’t hold boost up top. So one night I had an idea to test out a higher pressure actuator and wow it was the wake up call for that turbo!! I now was able to hold 28psi to my redline and have tested 30psi to 7k!! On pump and spraying meth I’ve seen 39lbs/min flow and I’m sure on e47 it’ll break 400hp
I’ve posted a ton in the K04r thread you can check it out here
https://www.cobaltss.net/forums/2-0l...o-swap-310943/
So I raced a 5.0
And a roll vs a buddy’s fully bolted K04 car
Old 09-26-2015, 02:18 PM
KMO43's Avatar
Thanks!! I try to keep it clean looking but she needs some love I've been super busy
Old 09-26-2015, 02:23 PM
SylverSS/SC's Avatar
Look dad......wheels up!
Old 09-26-2015, 02:50 PM
KMO43's Avatar
Haha a Balt or 2 on stands is a pretty normal sight at my place
Old 09-26-2015, 03:17 PM
KMO43's Avatar
Stg3
I was really happy with how my car had been running on the bigwheel but I had been in love with the 7163 since I saw it was coming out and made the jump but I had a slight 5th gear set back again and Jon (SylverSS/SC) once again hooked me up with a LSJ LSD F35
Jonathan (Soundjunky) lent me his spare Intake manifold so I could make a mess of it! Plus some exhaust bit so I could get the coated after I ported them
I picked up a head from a guy and did a port job for some more flows!!
Here’s the ported head, stucs and supertech springs
I bought the turbo with the high boost actuator and it liked to run at 32psi so I switched to the medium and max was 29psi so I bought a Turbosmart dual port actuator now I’ve hit as high as 34psi and but currently am on 28psi. If you buy an EFR get one!
Love that boost curve!
KMO43's Avatar
Double post Fixed
Old 09-26-2015, 03:20 PM
KMO43's Avatar
Forgot to post but the 7163 thread I've shared a ton of info in there too
https://www.cobaltss.net/forums/zz-p...63-zfr-304838/
Old 09-26-2015, 03:22 PM
KMO43's Avatar
Stg4?
I’m parking my car here soon for the winter and will be doing a build again to go with the added boost and ported head but may also include.....
Thanks for looking and I hope you like my car!!
Old 09-26-2015, 03:43 PM
That turbo is huge lol good luck bro
Old 09-26-2015, 03:49 PM
KMO43's Avatar
Thanks eddy!
Not if taylor desides to be an ass and throws on that 6466!
Old 09-26-2015, 04:34 PM
CobaltSS 16's Avatar
This is a sweet car.. I like it. good story too lol
that thing moves out.
Old 09-26-2015, 04:37 PM
KMO43's Avatar
Thanks!! I have a lot to do today so i hope i didnt miss anything
Old 09-26-2015, 05:51 PM
tomj77's Avatar
So sexy. Just unhahn those charge pipes and intake, unless they are the new aluminum ones
Old 09-26-2015, 06:47 PM
Originally Posted by KMO43
Thanks eddy!
Lol let's see what happens I wish I could see the race go down in person
BTW you posted the stg 3 pics 2 times
Old 09-26-2015, 07:35 PM
Devin86's Avatar
Awesome man!! Good luck!! Everthing is looking great!! This makes me want this turbo so much more!!
Old 09-26-2015, 07:36 PM
I want that turbo as well maybe BF if not till next year
Old 09-26-2015, 08:22 PM
KMO43's Avatar
I'm thinking of custom making a 3+in intake with my buddy Kyle who did Jon's custom DP and getting it possible ceramic coated for heat control
Well come up to ND when it does down!!
I think this is the BEST turbo for our car good for DD around 400 and i guess we'll see what it can do next year
Old 09-26-2015, 08:28 PM
Well I think any turbo would be fine it all comes down to the tuning lol
I wish I could lol
Old 09-26-2015, 10:41 PM
nathan112i's Avatar
nice car bud, whats with the green coolant?
Old 09-26-2015, 10:56 PM
KMO43's Avatar
I'm cheap and have had 3 rads in my car so that's what I had
Old 09-26-2015, 11:02 PM
KMO43's Avatar
I wish I could lol
My choice would be K04r or 7163
I like tuning big turbos
Quick Reply: KMO43 FCOTM + Build Thread
