Forced Induction Turbos/Superchargers
Cant get into boost
Old 09-16-2016, 09:53 PM
because race car's Avatar
Cant get into boost
So a couple of weeks ago. 09 SS turbo, was accelerating (not full throttle) and at around 4000rpm heard a psshh sounds and the car went into limp mode. No leaking fliud, no bad sounds, sounds fine. But would not go into boost. Oil pressure light was on at first but went off, once we cleared the codes, it would start fine, but as soon as i let off the gas it shuts down like i turned the key.
So I took it to a shop and they replaced the MAF sensor , coolant tempt sensor, and some bad wires. So now it runs fine, except for the fact it wont go into boost.
It still has an engine code for the MAF. And it accelerates like a prius. Im going to be doing a boost leak test, but im wondering if anyone has any ideas as my money is running out while om fixing this.
MODS:
ZZP downpipe catless woth muffler delete
Hp tuned 24psi
Megan racing springs
Old 09-16-2016, 10:37 PM
cluelessk's Avatar
Codes you cleared would probably help.
You might of cracked your stock charge piping. Especially on 24lbs.
Old 09-16-2016, 11:10 PM
This, I'm betting there is a serious crack in a pipe or the intercooler.
Old 09-17-2016, 02:29 PM
63 Nova SS's Avatar
Bet it's the endtanks.
Old 09-20-2016, 09:57 PM
On my day off ill lift her up and take a look at the endtanks. Since its running right now (even without boost) i'm avoiding clearing the po101 code
Old 09-21-2016, 07:43 PM
cobaltssdude420's Avatar
Could be a turbo block off plate. I got the zzp catless downpipe and a bov installed, tuned and they found a boost leak. So now I need a $50 block off plate that costs $92 for shipping for **** sakes
Old 10-05-2016, 09:50 PM
So a bit of an update, I picked up a code scanner incase this happens again so I can know what is going on. Today I took her to a shop that is known for being good with turbos. Still running the p0101 so they tested the MAF, that wasn't the issue.
Next they ran a boost leak test, nothing. Then a smoke test, again nothing. They also check the wastegate and a few other things along that way, and were stumped. So next week they're having another mechanic look at it for the day while he looks up more information about these cars.
I'm suspecting it is a wiring issue, anyone got ideas?
Old 10-05-2016, 09:57 PM
Where are you in Canada?
Old 10-06-2016, 01:03 AM
PEI.. ******* rust belt. Also now the damned think dips from 400 - 1400 at idle every few minutes.
Old 10-06-2016, 08:49 PM
Another update, to see if the codes were from before the sensor was fixed, they were cleared. There were 2 p0101s, one thrown, one pending. Clearing the first, the light turned off, and the car still ran the same (pseudo limp mode with slightly erratic idle), clearing the second, the car went nuts. and is running hella rich and the RPM will go from 1100 - 400 and even just shut off, but giving it gas, it runs like before the codes were cleared.
Old 03-07-2017, 05:15 PM
Coldballss's Avatar
could it be the maf? had this problem on my old subie turbo.
Old 03-07-2017, 05:33 PM
That code is usually a boost leak
SaltyBalt's Avatar
I'm guessing that its also the intercooler. On my other car, 2014 WRX, the oem intercooler is of similar style and when I threw a manual boost controller on and opened the injectors up to run 20 psi I blew the endtanks off at the crimp connections to the factory end tanks. Got myself a Process west verticooler and its been awesome ever since. Is there a similar welded metal end tank intercooler for these cars?
Old 03-07-2017, 05:35 PM
SaltyBalt's Avatar
Oh hey another subaru fella! What subie did you have bro? I've got a 2014 WRX hatch as my daily right now but I intend to swap the cobalt to DD duty and build the wrx to be a track monster!
Old 03-07-2017, 05:36 PM
Coldballss's Avatar
1992 Legacy Turbo beater. I'm not really a subie bro, just have the piece of junk for winter dd duty, when it works.
Old 03-07-2017, 05:42 PM
SaltyBalt's Avatar
I feel ya. Subies always be breaking parts. Those old legacies have the most desired subaru engine though the ej22T. Factory closed deck and can take loads of boost. But I guess they also work well for dd duty. Hate to see it not enjoyed by someone who doesn't know what they have.
Old 03-07-2017, 05:47 PM
Coldballss's Avatar
I know what i got, but just the body is all rusted out from winters up here so its a piece of chit. motor will get saved when it goes to the scrapper.
Old 03-07-2017, 05:49 PM
SaltyBalt's Avatar
Oh awesome! good to hear that! Let me know when you pull that engine! I may want to have a spare block once I go racecar on the WRX!
Old 03-07-2017, 06:02 PM
Coldballss's Avatar
yeah no. its mine. for my future build.
Kolbalt_zz (03-07-2017)
Old 03-07-2017, 10:38 PM
Holy fail, nice try trolling must be butt hurt from a race.
Old 03-07-2017, 11:48 PM
SaltyBalt's Avatar
Not sure what you're talking about? The endtanks of the intercooler blow off quite easily with the plastic endtanks crimped to the metal core even when pushing stock boost levels. Just speaking from personal experience and it looks like the intercoolers on these are metal cores with similarly crimped plastic end tanks. The crimps are weak.
Not butthurt about any races at all either. Haven't had the WRX on track yet. Still a street car to have fun with through mountain roads.
Old 03-08-2017, 07:13 AM
just go drive your wrx and leave this forum, you're only here to try to troll and you're really bad at it.
ThoR294 (03-08-2017)
Old 03-08-2017, 08:55 AM
ThoR294's Avatar
my 14 wrx had rod knock at 9k miles. All I needed was a new short block. way easier than a new intercooler thats for sure
Old 03-08-2017, 08:57 AM
I thought rod knock and piston slap was factory standard on the wrx
Old 03-08-2017, 09:03 AM
ThoR294's Avatar
Yup. Friend has 14 sti hatch, he has had the motor replaced twice, new turbo. car had 38k miles 1st motor 2nd motor at 41k. he is on his 3rd motor now. 225 miles later, cylinder 4 misfire. needs another motor
Quick Reply: Cant get into boost
