Coolant interface
Are you asking how to check it, or why the coolant is low and the intercooler coolant is high?
The two systems are independent from each other. The only place where the two even come close to interfacing is at the intake manifold where the laminovas are. Even then, you could not get coolant from the engine into the IC coolant unless you had leaking so bad that I doubt the car would even be running.
