Forced Induction Turbos/Superchargers
Exhaust manifold bolt torque specs
Old 06-17-2014, 11:55 PM
Darkfuzion's Avatar
I have a repair manual that shows that 112 inch lbs are all that is required to torque the bolts down on the exhaust manifold, that's not really that right at all. I have a 2008 t/c and I am doing a turbo replacement right now, I just think it require more torque than just 10 foot pounds?
Old 06-18-2014, 12:50 AM
Grave's Avatar
That's what the GM service manual says as well. I haven't had any leaks. I also tightened in the correct sequence.
Old 06-18-2014, 07:35 AM
Administrator
Administrator
Staged07SS's Avatar
This is key.
Old 06-18-2014, 08:53 AM
Can you post up the sequence or point me to a thread where its listed? Helping a friend do a zfr swap this weekend and want to know just incase we have to pull the exhaust mani
Old 06-18-2014, 02:55 PM
Grave's Avatar
Here is the sequence. I forgot about tightening a second time. It will pull down a bit more.
Old 07-01-2014, 01:25 PM
i944scania's Avatar
mine was good for the first month or so. zzp cast manifold and gasket. then started the most faint annoyance
Old 07-02-2014, 06:25 PM
Darkfuzion's Avatar
Do you think the torque specs are too low?
Old 07-02-2014, 06:36 PM
umrdyldo's Avatar
no you are fine.
You don't want to over tighten or you will have a bad day. Stick with what the book says.
Old 07-02-2014, 07:08 PM
Blairwolf's Avatar
Good info right here. I need to install my header next week.
Old 07-24-2014, 09:15 AM
i944scania's Avatar
i guess i didnt follow the exact pattern according to the book. but i did a cross pattern
Old 11-18-2014, 01:40 PM
boostbalt's Avatar
Where can I buy that manual!
Old 11-19-2014, 12:00 PM
Grave's Avatar
It's the GM service manual. I was going to say ebay, but the prices there seem sketchy. CED has them for less. If you do try ebay, there should be three volumes.
Old 11-19-2014, 05:27 PM
boostbalt's Avatar
Thank you
Zharrington_2010LNF
02-08-2016 01:43 PM
01-12-2016 12:01 AM
10-13-2015 09:32 PM
SSLOW06
10-01-2015 07:21 PM
09-27-2015 08:53 PM
Quick Reply: Exhaust manifold bolt torque specs
