Hahn or Vulcan?
i'm an LSJ. i have no idea if theres would work on the LNF
i remember there was one guy that put the vulcan on his 2.2 as a normal manifold though lol
bump, more oppinions please
Last edited by EXsoccer1921; 09-22-2009 at 11:35 PM. Reason: Automerged Doublepost
Just talked someone through some help cause they welded the TB flange on wrong on the vulcan, which ive heard happening more than once.
He also was explaining that the sensors wouldnt bolt right up, hes saying they have drilled holes for fittings and he was saying he would have to run a hose from his map, to a fittingo the intake manifold, which doesnt sound right to me at all...
The hahn is way nicer.. looks way better.. and also has a better design... the way the hoses and sensors bolt up is just ease over the vulcan.
hahn > all.. I have it so i can tell you how swee this thing is.
im going with the stg 5 S20G turbo from Hahn and should be installed shortly. Hahn is well known and just that reason alone I would go with them because more cars have went through there products so you know a little more what to expect.
