coolant change - Cobalt SS Network
Thread Tools Search this Thread
Old 03-10-2010, 08:38 PM   #1
coolant change
Have a 2.4L and it's time to change/flush the coolant/antifreeze.
1.How do I take off the splash shield underneath the radiator? How many clips or screws are there or do I just have to yank on it?
2. Does the rad drain from the left or right or both sides
3. Do I need to flush and refill with distilled/purified water or can I use tap water or brita filtered water?
4. Where is the water pump located in case I want to drain from there as well to drain it more completely?
Thanks in advance
kush is offline   Reply With Quote
Old 03-10-2010, 09:33 PM   #2
Images: 2
Thanks in advance
1. There's a bunch of clips and 7mm bolts holding the splash guard on. If it doesn't come right off, you missed something. Keep looking.
2. I drained my radiator from the lower passenger side...there's a stopcock there that drains the whole thing.
3. I used tap water and I haven't had any problems.
4. The water pump is between the engine block and the firewall slightly to the passenger side. It's pretty much the only pump looking device on that side of the car, and it has a single drain plug on the bottom. If you need a picture, let me know and I'll see what I can dig up for you.
jmz250 is offline   Reply With Quote
Old 03-11-2010, 02:42 AM   #3
Do those clips just pull out? They seemed to be pretty stuck on there
Old 03-11-2010, 10:09 PM   #4
Images: 2
Yes, they pop out. You'll probably need a flat head screw driver and/or needlenose pliers. The bolts are 7mm.
Old 03-11-2010, 10:16 PM   #5
Images: 183
drain the system fill it with water and then run it for a few cycles and then drain it again if your that worried bout getting the system that clean, taking anything apart on the water pump is pointless unless your going to replace your t stat too. buut the pump is in the back on the pass side, follow the water tube in the back under the header. you can use tap water to fill it back up with coolant or distilled water.
OneCOLDBIZL272 is offline   Reply With Quote
Old 03-13-2010, 03:17 AM   #6
Ok, i think i'm missing something. I went at it and I ran into some trouble...The middle splash shield that is right under the radiator is what is supposed to come off right? It seems like its permanently connected to between the radiator support arm and drainage valve.
Or am I taking off the whole right side shield that goes up into the wheel well too?
Old 03-13-2010, 08:40 PM   #7
Images: 2
The right side shield that goes up into the wheel well.
And there's a drain plug on the bottom of the water pump. You can drain more out at once so you don't have to run as many cycles.
Old 03-14-2010, 05:31 AM   #8
Oh, I thought that the whole wheel well thing just seemed like too much work when it looks like all that needs to come off is that tiny little plastic guard under the radiator lol. thx
Thread Thread Starter Forum Replies Last Post
"supercharger Collant" leak brandon04 Problems/Service/Maintenance 46 10-21-2015 08:04 AM
Wrong Trans installed under warranty? importkiller Problems/Service/Maintenance 11 09-30-2015 08:18 PM
Second Wind MrInsanityWolf New Members Check In!! 3 09-29-2015 05:54 PM
For Sale Silver 2009 Cobalt SS Sedan grampss Complete Cars 0 09-27-2015 09:51 PM
Official painted coolant tanks thread riceburner Appearance 13 09-26-2015 01:57 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
