coolant temperature to worries??
What is the highest temp of coolant before over heat.. Because when i was stuck at HIN my temperature gauge hit 230 so i crank up the heater and temp. slowly drop until i can get a parking space..Was a little worries.. I check my manual, no temperature danger is indicated... my avg is 185
Is there some thing wrong w/ my coolant system cause 230 is kinda close to 260 no?
That should never happen though unless you spring a leak somewhere. A leak, even if no liquid comes out, causes the system to lose pressure and the coolant will boil at a lower temp.
God you people kill me.
Originally Posted by StreetDreamz
Yes there is because 180 is close to 260 also. And your car runs at that all day. So just a few degrees more will totally blow your car up and the dealer won't warranty it because they will say it's abused.
Originally Posted by DWK5150
Any one what temperature the cooling fans come on at?
my car averages around 180 - 190 when driving around.. but when im in traffic i have watched it climb into the 21x range..
you dont need to worry though... high water temps is a common GM occurance.. every car i have seen/known/worked on etc. have always ran above 200 even with 180 t*stats
I think having a digital readout of the temp is what's getting most people worried. Just about every car will run like this, but most newer ones with actual gauges for the temp will always stay in the middle. What most people don't know is that it's programmed to stay in the middle unless the temp goes outside a certain range. (say 175-235)
Not sure what it is at all, but when it comes to the cooling system, I'm a big believer of don't fix it if it ain't broke. I'd be careful about adding anything to the tank.
My 2001 Ranger ran between 190 and 210 all the time... I dropped a 180 degree thermostat in it... made a huge difference... cooler is typicaly better... to a degree... modern engines run so hot to meet emissions standards.
I hit 226 sitting in a construction zone on a warm day. And then the fans kicked on and brought me right back down to 185 where I usually am. Like someone said, you'll start boiling at 260, then you can worry.
No I didn't FEEL the fan kicking in. But the temp hit 226-ish and then suddenly started dropping even though I was still just sitting there. I figured that had to have been the point the fan kicked on.
Originally Posted by beerbaron105
sitting in rush hour traffic in the middle of summer ive hit a max of 112C - what is that in fahrenheit? it seemed disgustingly high, usually its around 82-86C
The big single fan on my old Pontiac though...that thing dimmed the lights when it fired up.
Again, even running at 260 won't damage then engine. What damages the engine is when the coolant gets so hot that it boils and turns into steam, and loses the ability to transfer heat from the engine. At that point the engnie temp sky-rockets out of control. That's why if you kill the engine right when the coolant temp goes over 260, you have nothing to worry about as far as internal damage. Just a broken cooling system.
i ve watch mine hit 230' until the fan kicked in. took a few seconds to bring it down to
190' which is about where it runs. but i too was a little worried watching my temp STEAM higher temps! btw i was sitting in a fast food drive through.
