Did you Disconnect the Battery Before Installing Your Intake?
Old 08-11-2008, 12:12 AM
Nymostwanted187's Avatar
yes i did and no cels. and its the ground black one.
Old 08-11-2008, 12:13 AM
wordsthatiwrote's Avatar
Originally Posted by wardzach2007
Oh, okay...
How do you disconnect the battery? Remove the red (positive) or black (negative) first? Red one right?
Im a noob, yes I know. But I havent done this since Auto tech.
Just the negative side. You dont need to remove the battery. Its a circuit. If you make a break in it, It would do anything. I disconnect the black.
Old 08-11-2008, 12:15 AM
wardzach2007's Avatar
So all you do is turn off the engine, and remove the cover to the battery, and disconnect the negative? Hmmm, sounds pretty easy.
Lol, i said i would of removed the red one first. LMAO, i would've died.
Old 08-11-2008, 12:17 AM
Not a Sebring
WhiteSSBalt's Avatar
No. No codes thrown from it though. However now, the car has countless codes thrown....some from my cat-less midpipe, some from my car being un-tuned and running rich.
Old 08-11-2008, 12:19 AM
Thats what all the chilton manuals say to do. If you remove the red one, It could ground out the the frame and cause even more problems.
Thats not good. That can actually wreak havoc on your .......CAT......which i just saw that you dont have.....
Last edited by wordsthatiwrote; 08-11-2008 at 12:19 AM. Reason: Automerged Doublepost
Old 08-11-2008, 12:27 AM
ScottxKillyou's Avatar
In my 05 ss/sc, when i installed the K&N filter, i disconnected two things from the air box. One was the big MAF, and I dont know what the ohter one was. DOes anyone know? It was a small box connector to the box.
probably MAP sensor (Manifold Absolute Pressure)
Old 08-11-2008, 12:47 AM
When you installed your intake, did you connect two connectors to the intake?
Do you need that for the intake? Or just leave it loose?
Last edited by wardzach2007; 08-11-2008 at 12:47 AM. Reason: Automerged Doublepost
Old 08-11-2008, 10:23 AM
OrngBalt's Avatar
Originally Posted by wordsthatiwrote
If its the wrong size intake. IE using an intake designed for a 2.2 application on a 2.4 I got a cel even after the negative disconnect. As one said before me. Live and Learn.
Well this doesnt apply seeing as the intake for the 2.2 and the 2.4 are the same intakes.
Old 08-11-2008, 11:50 PM
Not really. The fujita intake I had was about 2.5 inch diameter. My K&N is like 3inch. So Im sorry but I would beg to differ.
Old 08-12-2008, 12:05 PM
OrngBalt's Avatar
thats the individual intakes. Go look on ANY site. All the intakes are for either model. In fact 90% of the parts on the market are good for the 2.2 AND the 2.4.
Before you beg to differ, check out the data.
Sl0wbaltSS
11-21-2018 11:11 PM
no_ss
10-18-2015 11:58 PM
justinchinn
10-02-2015 12:18 PM
grampss
09-27-2015 08:51 PM
c_m_shooter
09-27-2015 04:40 PM
Quick Reply: Did you Disconnect the Battery Before Installing Your Intake?
