DO i need to tune?
DO i need to tune?
So i have a ported supercharger with a 2.7 pulley but the needle bearings are going bad and im about to buy a replacement. the new blower is also ported and im switching snouts to keep my pulley size the same. do i need to tune it for the new blower? its basically the same thing as i have on it now....im just a little worried because each hand port is different. I asked ZZP and they said i would be good without a tune. do you guys agree?
Before you go replacing the blower, pull the snot off and make sure the coupler is good first.
But I agree if all you're doing is replacing the blower pack you should need a new tune. I assume you have a wideband gauge? Watch that after you replace the blower just to check.
before you go replacing the blower, pull the snot off and make sure the coupler is good first.
But i agree if all you're doing is replacing the blower pack you shouldn't need a new tune. I assume you have a wideband gauge? Watch that after you replace the blower just to check.
