Driving Manual Tips
Old 02-24-2015, 04:47 PM
  #176
12andy's Avatar
Heel-toe double-clutching down into 2nd for every turn for me, city driving. The downshift commences at a fairly low RPM to avoid having to stab the gas pedal too much (around just over 1k RPM).
Best method for braking, gearing and steering control going into - navigating - and exiting a corner.
Anything else (barring the double-clutch) is a compromise, IMO:
- entering the corner in 3rd/ 4th, you're now bogging as you hit mid-point, and now have a split-second delay when downshifting into 2nd as you unwind the wheel; both hands are no longer on the wheel as well
- coasting through the corner is an instant fail
Old 02-25-2015, 09:19 PM
  #177
footballplaya3k's Avatar
Originally Posted by Pasierbek
Can I just brake-clutch-shift-blip-clutch out to downshift? I can't seem to blip before the shift cause my RPM's are already too low after my shift. Is my way bad? Also another HUGE issue Im having I cant believe I forgot to mention. Its reverse gear. Lets say im reversing into my driveway and this thing is fairly steep. I keep having to ride the clutch in, clutch out, cause if I release at the catch point, Im flying towards my garage door in reverse. Thats scary. Any tips?
If you shift into gear before rev matching you are causing a lot of wear on your synchros.
Old 02-25-2015, 09:39 PM
  #178
chris88z24's Avatar
No you are not. You'd have to double clutch to "save wear on your synchros"
Old 02-25-2015, 11:33 PM
  #179
Or don't downshift to slow down, which is my point
Old 02-25-2015, 11:35 PM
  #180
chris88z24's Avatar
Downshift all day every day
Old 02-25-2015, 11:45 PM
  #181
You must like replacing TOBs often.
Old 02-26-2015, 04:59 PM
  #182
UnkleRaRa's Avatar
2006 with almost 150k KM's and downshift everywhere..... TOB's good! (knock on wood!!)
Old 02-26-2015, 05:43 PM
  #183
Originally Posted by UnkleRaRa
No TC. No NLS. No RPD. lol... I have an LSJ not LNF. But even the LSJ can apparently do 67 in second... I'll be damned! I thought it was just a hair under 60. I try to stay away from redline. Slamming into the limiter unexpectedly can definitely pucker you up! haha
Mine goes almost 80 with the 7500 rpm limiter haha
2nd gear pull:
Old 02-27-2015, 09:13 AM
  #184
Pasierbek's Avatar
I think If I re-learned the order, I would be able to BLIP before the shift. Now that I think about it, it does make more sense to do that. I've heard of potential clutch wear as a downside of downshifting but Throw-Out bearing? Seems a little far fetched to me. From my research so far, I hear TOB's go bad if you rest your foot down on the clutch at every light and if you mash the clutch pedal to the firewall alot (which I think is why Powell made a pedal stop). I will continue smoothening out my downshifting but learning to do it the right.
Old 02-27-2015, 09:35 AM
  #185
UnkleRaRa's Avatar
As long as you keep the RPMS relatively low (below 3500), and dont ride your clutch or grind gears, you should be able to learn without worrying about too much damage to anything.
Old 02-27-2015, 09:49 AM
  #186
Havent been paying attention to this thread lately. You cannot properly heel-toe in this car, the gas pedal is fire wall hinged not floor hinged.
Also if everyone is looking at you when you rev match to down shift you're down shifting to early, you shouldn't down shift to 3500rpm if you're driving on the street (at the road track completely different).
I also don't notice a significant difference in braking in neutral vs braking in gear, the brembos can lock tires up and I'm sure the LSJ guys can lock the tires up with their brakes so you only have so much braking traction for a given tire.
Rice we can't use your car as an example of where second gear takes you lucky LSJ guys with the 4.05 I am super jelly you can get to 80 in second (I'm midway in 3rd at 80).
Old 02-27-2015, 10:23 AM
  #187
UnkleRaRa's Avatar
Where the gas pedal is hinged doesnt make any difference, its more about the spacing between the pedals.
As long as you can use 1 foot to blip the throttle for a down shift while at the same time applying the brakes, you are heel toeing.
It wouldn't matter if the gas pedal was hinged from the roof of the car, as long as its spaced properly from the brake.
I do notice a big difference in neutral braking vs. braking in gear.
But whatever style of driving you find comfortable, and keeps you safe, all the power to ya!
Old 03-04-2015, 03:52 PM
  #188
SaberD's Avatar
You have more precise control over the brakes with the car in gear since it's already creating force to slow down the car. Therefore less pressure is needed on the brakes, and then the brake pedal can be more accurately applied. It also reduces fade in endurance races with repeated braking. Dowshifting while braking also allows you to do 2 things in parallel saving lap times.
I have to say though engine braking sucks ***** in the LSJ. It's programmed to keep the TB open even when no fuel is being delivered to help with emissions. Still haven't found anyone who can tune it out. This is also why it takes forever for the RPMs to go down.
I heel-toe through every gear every single time I slow down. The car has 115k miles and shifts flawlessly. I don't even notice myself doing it anymore. It's pretty much automatic once you do it enough.
Old 03-11-2015, 01:39 PM
  #189
Pasierbek's Avatar
Hey guys, the downshifting is coming along nicely and it makes for a much more enjoyful braking to a light. I finally re-taught myself to blip and shift fast enough to catch it without any jerking momentum or any loud revving. It is like OP said, the passenger wouldnt even notice I was downshifting. One key thing to add for anyone else learning manual after me on this thread. Feel out the shift pattern! Precisely know where each "gear gate" (I think thats what its callled) is located and transition into it quickly but smoothly.
Old 04-07-2015, 04:28 PM
  #190
wordsandsuits's Avatar
good stuff. i like the double clutching myth bust.
Old 04-07-2015, 04:39 PM
  #191
12andy's Avatar
Care to elaborate?
Old 02-05-2018, 02:30 PM
  #192
Beyonson21's Avatar
I will say, the clutch in the cobalt is one of the easiest to tame. It is pretty lightweight, but my stock clutch can handle me dumping it a few times a month.
Old 09-09-2019, 07:26 PM
  #193
IanTheOz's Avatar
On my cobalt (ss/sc) it feels a lot smoother double clutching into second, like, a lot smoother. I don’t know why it doesn’t really make a difference with smoothness downshifting into any other gear but when I downshift into second double clutching just makes for a lot smoother of a shift. This isn’t a problem with second gear is it? Or maybe I’m just hitting it right when I double clutch and getting the timing wrong when I don’t. I don’t know, any thoughts?
Old 09-10-2019, 08:14 AM
  #194
jdbaugh1's Avatar
It feels smoother like it doesn't grind or just slips into gear easier/faster? If the gears grind you could have a bad synchro.
Old 09-10-2019, 10:39 AM
  #195
IanTheOz's Avatar
No my gears don’t grind it’s just a lot easier and smoother, it’s a lot harder for me to get that perfect downshift into second when I downshift normally than it is when I double clutch, it kinda puzzles me but I don’t think it’s anything to be too alarmed about it’s just a weird quirk. Probably means I suck at downshifting into second lol.
Old 09-10-2019, 10:47 AM
  #196
jdbaugh1's Avatar
I didn't know what you meant by "smoother". I'd assume that would mean if you don't double clutch that the shift is "rough". Only thing that comes to mind for a rough shift is when the gears grind. If you don't you can rev match by blipping the throttle as you downshift. This won't help engage in the lower gear as the clutch is disengaged but it will prevent shock on the engine and clutch because the transmission won't be trying to suddenly accelerate the engine when you release the clutch pedal.
KingOnso
05-31-2013 01:00 AM
bmccain2
08-07-2011 07:56 PM
metroplex
06-04-2009 11:54 AM
Zivnuska
08-12-2006 10:29 PM
Xenozx
02-09-2006 11:17 PM
Quick Reply: Driving Manual Tips
