door window molding/seal
Just wondering where i'd be able to order a new one, if its available somewhere other than a dealership. I recently f'ed my driver's side window up when opening my window while it was frozen shut (or so i thought). today the window wouldnt close properly, part of the seal had to be held in place or pushed/pulled while the window was being shut for it to seal properly. im sure i could just apply some sort of adhesive if need be. So in the case that i cant find a new seal or its to expensive to be worth it, what kinda of adhesive should i try using?
kthx bye
kthx bye
idk, is there a couple diff parts to it? its not the thicker seal for the door its the one that goes between the window and fram of the door. if u look at ur car, u can see like a 3mm wide part of it sticking out around the frame of the window. if its all one piece tho ill take a look around the area to see what i can salvage. thanks
yea i know , i was just using that as an example, ive never pulled mine out so i couldnt tell u if its one pievce or not, but id say your best bet would be a scrap yard
Nope it just slides on, or pulls off. I take 5 or more of these off a week. lol Im a Auto body tech. But just to make sure you are talking about the belt strip right? in the link I sent you it would be #1.
