Injector Cups?
Injector Cups?
I know stupid thread to start, but I'm trying to identify the name of the grey plastic cups that go into the LIM that the injectors seal into.
Yes I have googled multiple ways of articulating this to no avail.
EDIT: I put this in LSJ not general because I'm not sure if the other motors use the same piece.
Thanks
Thanks
07_Red_SS/SC (01-20-2017)
Make sure you oil or grease the O-rings or they they can roll out of the groove and cause vacuum leaks. Let me know if you find a part number/source for just the factory O-rings.
I planned on it. As far as replacement o ring seals, I bought a kit from Jegs or Summit that was a large assortment of nitrile o-rings that I use on fuel injectors and such.
Similar to this http://www.jegs.com/i/Vibrant-Perfor...20999/10002/-1
but had about double the sizes
