loud clicking from dash "fix" - Cobalt SS Network
Thread Tools Search this Thread
Old 06-04-2012, 04:12 AM   #1
Images: 3
Hey there, I know a lot of people are gettin the loud clicking from the passenger side inside the dash when they turn they're key on. As you may know its the actuator for the door that controls the recirculate function inside the airbox . Everyone seems to believe you have to tear your dash apart to disable it. If you have small enough hands and a little patience, there is an easier way to unplug it and not have to hear the annoying noise every time you go to jump in your car. I unplugged mine (its not working anyway because the gears in the actuator are stripped) and it doesn't affect the heat or air conditioning at all, just the recirculate function. If you scoot the passenger seat all the way back, and lay on your back on the floor, reach up above the side kick panel in the small space between the dash and the body of the car in front of the passenger door. Its about six inches up, you'll find two small wires taped together (not the wires for the blower motor!). Follow them up to a plug. You cant see in there so its all by feel. Theres a blue plastic key you have to snap out with your fingernail, then just give the plug a firm tug and it should pop right out. Mine has been working great and I done have to hear the horrible noise anymore. Hope this helps guys, and good luck!
Galadrake is offline   Reply With Quote
Old 06-04-2012, 11:42 PM   #2
Images: 1
Just to make sure I understand you you are talking about the clicking when the fan is on right?
06_cobalt is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Clicking Noise biniecki Problems/Service/Maintenance 8 10-25-2015 03:23 PM
Wow, Check out this rack Mr Mall Cop The Lounge 19 09-28-2015 08:10 PM
2005 LSJ warm start issues? OrangeK Problems/Service/Maintenance 0 09-20-2015 04:02 AM
Loud squeaking noise at low rpms Infamous SC/SS 2.0L LNF Performance Tech 5 09-04-2015 06:33 PM
Catastrophic failure due to manufacturing fault... now what Adam144 Problems/Service/Maintenance 5 09-03-2015 08:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
