needle bearings
needle bearings
Anybody know anybody in harrisburg Pa that works on superchargers and can fix my needle bearings for me? im going to have Jeff Reiland do them but im driving the car to him so it can be fixed in one day but its a 4 hour drive so i thought i would look around to see if there is anybody closer to me first.
I want to say people usually don't have issues with the needle bearing on the M62. It's really easy to take the supercharger off and check the coupler and replace the oil (don't buy the GM over priced repackaged Mobile 1 Syn Oil)
and i am running a 2.7 pulley which i have been told will lessen the life of my bearings. and i thought bad needle bearings is what makes the rotors scrape anyways.
In the Duramax world we get conflicting things all the time. GM says use Dex6 in the Allison but Allison the company says TES-295 fluid only and the Dex6 can cause problems. I normally go to the manufacturer of the part.
iirc 5-w30, maybe staged or metallic will jump in here and comment
All it's doing is lubricating a few bearings and some gears, if you're close on the weight its not going to cause significant damage. You're not dealing with a complex system like an auto trans where the fluid is pressurized. It's just an oil lubricating bath.
Isaac Lewis (01-13-2017)
