Please post pictures of the stock jack points
Old 12-30-2007, 01:39 AM
jackjohnson_218's Avatar
Originally Posted by red07g5
That oosing stuff is just glue that they use to seal the body up, it just got painted later. If you look in the trunk, next to the battery, you can see little globs of the same gluelike stuff that covers drain holes that are there to drain the body after they dip it to keep it from rusting.
WTF did you put all over the bottom of your car? Looks like that truck bedliner stuff...I personally use a 2x4 that I cut a groove in that mates with the ridge, I also contoured it to hold a jackstand nicely.
I got the dealer to throw in an undercoat before I picked it up.
Old 01-03-2008, 01:36 PM
Came across this link too with some pics. Hope it helps:
https://www.cobaltss.net/forums/show...=jacking+point
Old 02-14-2008, 08:28 PM
tru2nrtt777's Avatar
I used the pinch weld until about a week ago when I was jacking it up with my floor jack and had the tire about an inch high, came back and it was on the ground, thought the jack lost pressure and pumped once more to hear a nice loud crunch... now I gotta beat the weld back straight...
Old 02-14-2008, 10:27 PM
LopsidedJester's Avatar
i have to bang out the pinch as well, definitely not doing that again
Old 02-14-2008, 10:38 PM
outtamymind's Avatar
thats weird cuz thats all i use and have done many a vehicle by those and never have had that happen
Old 02-29-2008, 06:43 PM
and I have been the same way until now...
Old 05-17-2008, 10:39 AM
My06Kobalt's Avatar
Originally Posted by jackjohnson_218
I have driven honda's all my life so when I looked under to find the 4 jack points (indicated by the arrows), I was quite surprised.
On all my other cars the jacking point is a thick steel piece about half a deck of cards thick. There is none as you can see below.
First off, in the pic below, does anyone know what that foamy stuff oozing out of the ridge is? Some of it flaked off when I touched it.
And Second, Im pretty sure that thin ridge where the arrow is pointing to is not going hold worth **** as I almost bent it with my hand (well at least it seemed that way ). Would you recommend jacking at any of the two places where I circled? I beleive the part circled in yellow is what the fellow was talking about when he brought up using the "Jacking Pucks".
https://www.cobaltss.net/gallery/fil...JackPoints.jpg
don't jack up where you circled in red. i did that to my girls cobalt, and it slowly started to cave in.
Old 06-23-2008, 03:31 PM
kapster's Avatar
Yeah i learned that lesson too the first time I used a jack on that red circle. usually there will be a cut out in the pinch weld as a marker for the jack but none in this car.
Old 07-09-2008, 12:09 AM
rukkee's Avatar
The seam that the arrows point to are only to be used with the jack from the car . There is a nice little craddle in the cars jack that the ridge fits into. Cant believe people are using a floor jack on the seam, what do you expect that seam to do except get flattened ? lol.
Old 07-09-2008, 08:50 PM
PolishPauL's Avatar
Theres no where else to use it. Has anyone found a reliable spot to jack the car up? I hate workin on my car cuz im worried that im gonna bend the points im jackin like i already did to the car jack seam.
Old 07-09-2008, 09:26 PM
  #36
BeermanSSSC's Avatar
**** that link was good info, i hate doing this too i fucked mine up a little had to realign the front quarter panel cause that **** bent to hell. All my other cars had frames that was so much easier. Unibody **** sucks. Had to spend like 2-3 hours fixing **** after the jack stand started to bend everything, luckily i caught the car with the floor jack really quick and got it off. but **** the quarter panel was touching the door.
Old 08-02-2008, 10:30 PM
  #37
theneelster's Avatar
Back from the dead...but on the cobaltss/redline you're supposed to use the thin subframe you see in those pictures with teh "wtf" circle. The factory scissor jack is grooved for that particular point unfortunately if you use it with a non-scissor jack it may bend or groove the subframe and make things a tad more dangerous when swapping tires.
Old 08-02-2008, 10:51 PM
  #38
Doc
Doc's Avatar
I'll post a solution to this once I get home. (Can't get to photobucket at work)
Old 08-03-2008, 09:10 AM
  #39
Doc
Doc's Avatar
here is the modification I mentioned, subframe bar by U-RaceCars.
Old 08-03-2008, 09:13 AM
  #40
sick06cobalt's Avatar
what is that doc?
Old 08-03-2008, 09:16 AM
  #41
Doc
Doc's Avatar
I got a set of subframe bars from U-RaceCars, to give you a better idea what they look like. This is during the install.
here http://www.uslsja.com/index.php?topic=1438.0
Old 08-03-2008, 09:48 AM
  #42
was the install hard?
Old 08-03-2008, 10:23 AM
  #43
Doc
Doc's Avatar
Not at all, we measured like 10 times before we installed anything. Mine was the first set on a cobalt so we'd go out, mock them up, take pics, then take a break, then go back out and finish That and it started to rain, so we got something to eat while we waited.
Old 08-03-2008, 12:23 PM
  #44
PolishPauL's Avatar
How much do they help with handling? I don't have $500 to spare though.
Old 08-13-2008, 12:13 PM
  #45
PrtyNkd's Avatar
Always lift your Cobalt from the pinch welds. there isnt a safer place to lift it..those arrows are there for a reason
Old 08-13-2008, 12:23 PM
  #46
thought's Avatar
To the OP: WOW - Yeah, don't put the jack ON the arrows, they are just pointing to where the pinch welds are to slide the jack under. They are just plastic ground effects.
Old 08-13-2008, 12:24 PM
  #47
Haz l33t wheelz.
ls1fbody's Avatar
that is ONLY for the sock jack.
if you're using a floor jack, haha go Doc's route, or like:
Post #6 on the first page is good as well. i lift my car a lot, and the weak points on the underside prove where i tried and failed. i've found every hard point on that car, there aren't many.
Old 08-24-2008, 12:17 PM
  #48
PolishPauL's Avatar
http://www.torinjacks.com/ProductDet...x?ProductId=94
Thats a easy way to do it or you can use a air gun on the stock jack.
For the stock jack, if I keep leaving the car on it, with jack stands under just in case, will it eventually fail from wear?
Old 10-10-2008, 12:48 AM
  #49
Fail Less.
Bika's Avatar
never leave your car supported by a jack for long periods of time. always set it on the stands.
everything will eventually fail from wear, but since its not a hydraulic jack, i see that taking a very long time.
I wish I knew not to use the red circled part to lift the car. I scratched the hell out of it and pushed it in some Which reminds me, I should prep and paint that before winter...
Old 10-10-2008, 05:30 PM
  #50
PolishPauL's Avatar
I always put two jack stands under just in case it falls, but sometimes i dont drop the car on the stands.
Quick Reply: Please post pictures of the stock jack points
