Trunk release
use a voltage tester to make sure the power is getting to the wires in the trunk that pop it. if so, check connections. if connections are good, replace the latch.
use your key fob
use your key
keep your back seats down and army crawl to get what you need in the trunk
use your key fob
use your key
My button doesn't work and I checked the fuse. Don't have the key fob and the physical lock won't turn. I fought to get into my trunk from the back seats and gave up lol. I'm going to bite the bullet and pay to have someone replace the locking mechanism on it.
I have to move my key around a bit to get it to open the trunk. Try lock de-icer and then moving the key a bit in and out while trying to turn.
Also it's pretty easy to pull the panel off that the button is in, then you can check the wiring easy or make sure the button is actually hitting the switch.
All I did was ask about my trunk not opening properly and your all just being rude! Just stay out of my thread instead of being insulting! Just wanted some help!
I know it's easy to ramble on and understand your own text but from our point of view we can't make out what you're trying to say.
ECOTEC06SS
07-12-2010 11:49 PM
bboyfreeflow
08-31-2009 09:13 PM
