Upper trans mount upgrade worth it?
OTTP,ZZP, and even Powell all use the same mount bushing.
As for the front mount being the weakest. It's best if you know what you are talking about before you give advice..... Maybe you guys should play with the stock upper trans mount. It is in fact the weakest mount on the car. Don't take my work for it though, ask anyone who has removed there trans. The front mount and the rear mount are of a similar design and strength. GM also replaced the upper trans mount on the race cars, along with the front and rear mounts.
Definitely know what im talking about in the sense of weakest, I ment replacing the front mount shows the most noticeable change for hard driving. Sure GM changed the mounts probably vibrated like hell too. I know the upper trans is the softest soft. I literally said get a front and upper trans mount you can stay with the rear stock. He's not making his car into a race car so the stock rear will be fine for him.
Doubt the bushing are the same, but I guess you would know the competitors stuff.
The rear stock rear mount is fine. The stock bushing will probably outlast the ottp one anyways. zzp's newest mount is a rotated rear for cars with a rotated front mount for lower cars you can try that if u want. The front mount is the weaker of the 3 that's why you change it. The upper trans mount just came out not to long ago? And everybody did just fine without it for years. But now it's here so grab it Just cause it says upgrade in the description doesn't mean it's better. It's just different.
Yeah zpp has rear that's rotated now. It doesn't have the spacer, just a solid piece. The other rear they had was just stiffer. Now ppl with lower cars and zzp mounts will be much happier lol if they want to pop that new 1 on.
The cars with Powell stage1 or ottp mounts with a spacer in the rear don't need them. But if u have zzp mounts yes get the new rotated rear
Good to know!
When the time comes (likely later this summer) I'll be getting all powell mounts, likely his suspension mounts too. He's somewhat local so I can pick them up.
#36
lucky wish I didn't have to pay that damn exchange rate lol! Yeah get his trans mounts and control arm bushings you won't be sorry!
#39
The front isn't the most noticeable change. The reason you think that is because of marketing. There is no easy way to change the location of the stock front mount with a spacer. The rear is easily done. So it makes sense to sell it that way. The problem with keeping a stock rear mount is that it will just compress the bushing to get back to where it wants to be. A front mount with rear spacer is only a half fix.
#40
Bushings are 100 percent the same now. In the past they weren't.
#41
My purchase will most likely be ottp stage 1 and to hopefully fix some of my hard shifting ottp short shifter with bushing and clamp along with new shifter cables. Hope this makes the ride more comfortable
