Hahn RaceCraft Hahn RaceCraft Is a Supporting Vendor of CobaltSS.net
Contacts: EcoBoost ; Hahn Sales
2.0 TurboSystem: How would YOU want it?
Old 04-24-2008, 07:00 AM
  #176
2K5SS/SC?'s Avatar
Bump for prices and turbo love!
Old 04-24-2008, 08:02 AM
  #177
silentd's Avatar
i was just looking at the pictures and was wondering is this a cold air system? it looks like the intake is on the left of the motor sucking hot air? also will this fit with the dual pass system (theres an extra resovior) or is that not needed anymore
edit: im pretty sure im an idiot, the air passes through the intercooler first doesnt it
Old 04-24-2008, 08:37 AM
  #178
MoneyPit's Avatar
Subscribed Hence my name lolz
And yes the air passes through the air to air intercooler before it hits the intake. As far as the air filter that you see next to the motor that is what is fed in to the turbo 3'' inlet. And that can be some what hot since it will be passing through the intercooler before it enters the cylinders.
Old 04-24-2008, 11:19 AM
  #179
luciano23456's Avatar
Why is it that i was under the impression that the air went from intake to turbo to intercooler to manifold.
Old 04-24-2008, 11:39 AM
  #180
MoneyPit's Avatar
It's really to hard to explain over this. Here is a link go read these. They will help you understand exactly how a turbo system works.
http://www.turbobygarrett.com/turbob...o_tech101.html
Old 04-24-2008, 11:41 AM
  #181
it doesnt make sense to cool the air then compress it because its just gonna heat right back up. pressure and heat go hand in hand. so it only makes sense to pressurize it then cool it down while keeping the pressure up so you can have a nice dense air charge without the power robbing heat.
Old 04-24-2008, 11:50 AM
  #182
MoneyPit's Avatar
I'm really not to sure what you're trying to say, but if you click that link the first thing is a picture diagram showing you the flow and setup of a turbo system. Hopefully someone can help you out more than what i can. Sorry man
Old 04-24-2008, 12:37 PM
  #183
2K5SS/SC?'s Avatar
luciano, you are correct here.
1. Air gets sucked in through the filter to the turbo inlet.
2. Air gets compressed in the housing using the exhaust gases to do the work.
3. Hot compressed air comes out of the turbo and flows through the intercooler and then it becomes cool compressed air.
4. Cool compressed air goes through the throttle body, into the intake manifold, and finally into the combustion chamber.
Old 04-24-2008, 12:40 PM
  #184
06blackg85ss's Avatar
****, no wonder why my car isnt working right...
lol j/k
Old 04-24-2008, 01:07 PM
  #185
Your either reading it wrong or its wrong all together. i haven't seen it myself so i couldn't say for sure. i may not have a degree or an outstanding track record but i like to think myself smarter than the average bear
Old 04-24-2008, 01:15 PM
  #186
MoneyPit's Avatar
Sorry but number three is wrong unless u are saying this. I'm not to sure from how you worded it what you ment.
The exhaust gasses never re enter your motor. They travel through the turbos hot side which spins(spools) the turbine blades then the exhaust gasses are released out in to the downpipe. Air is generated from the intake side(cool side) of the turbo when the exhaust side blades spin they are connected to the cold side and they spin which creates air. The two forms of air never mix.
Am i right here??
Old 04-24-2008, 01:17 PM
  #187
never in that post does it say exhaust... it says hot compressed air, which is correct... why you think it's called the hot side on the IC piping. there is nothing to do with exhaust in that post
  #188
Edubs's Avatar
Originally Posted by MoneyPit
Sorry but number three is wrong....
He never said they did...
You should really be careful trying to teach someone w/ a custom built turbo car how a turbo system works.
  #189
haha beat u to it
Old 04-24-2008, 01:18 PM
  #190
Edubs's Avatar
Originally Posted by 06blackg85ss
haha beat u to it
F*ck you Paul!
Old 04-24-2008, 01:25 PM
  #191
MoneyPit's Avatar
hey hey i fixed it it's not teaching calm down guys
Old 04-24-2008, 01:26 PM
  #192
FryLoch's Avatar
Can't wait to get my hands on this kit. Will it be possible to get 79s and a tune with this kit?
Old 04-24-2008, 01:29 PM
  #193
05sattyredline's Avatar
i think i see what you guys are getting at... basically taking this setup and running a turbo in between the DEI piping right:
lol had to resurrect that one
Old 04-24-2008, 01:34 PM
  #194
MoneyPit's Avatar
HAHA i remember seeing that and that was the best thing EVER!!
Old 04-24-2008, 03:48 PM
  #195
You didn't fix anything thing because there was nothing broken. you were misinformed. you probably read the diagram wrong just like you did that post. but i digress, when can we expect track times for all these cars. i know there is still work to be done but just a guess
Old 04-24-2008, 05:10 PM
  #196
Smarty Art's Avatar
You could fry LSJs in a quarter of the time.
Old 04-24-2008, 05:21 PM
  #197
BlackMachine's Avatar
how much do u guys thinks level three would cost on an install? 500?
Old 04-24-2008, 05:36 PM
  #198
MoneyPit's Avatar
Meaning i fixed what i said in the post that i miss typed and left a part out. Dude stop getting bent out of shape over this. What i don't get is ALL air is HOT when it comes in from the air filter/intake. Being were it will be above the fender well is a good idea because air flow does travel up that and it is out of the way of all elements. Let it go man, if you don't like his set up that's cool don't buy it. But I'm sure Bill knows what he's doing with this design.
Old 04-24-2008, 05:40 PM
  #199
Smarty Art's Avatar
Yeah. If you really wanted to get frosty air then you could move the washer tank and run the intake in the fender.
Old 04-24-2008, 05:45 PM
  #200
MoneyPit's Avatar
Hey dude ya i was thinking of that but i wasn't sure as to how wicked of a bend you would have to make to stay under the hood clearance and stay above the motor mount since its a 3" pipe. I might try it once i get the kit.
Quick Reply: 2.0 TurboSystem: How would YOU want it?
