Other/Misc: Adding the Boost Parameter to Your Dashdaq
Old 03-11-2012, 06:37 PM
Stamina's Avatar
Post Adding the Boost Parameter to Your Dashdaq
First off, make sure that you've got the latest firmware and Rescale Signal Calculator module installed on the Dashdaq. To do this, follow the manufacturer's instructions. The Dashdaq in this How-To was running 2.1.6-2096.
Once this is done, you're ready to begin.
Go to Setup>Devices>Manager and find an unused device slot.
Then click Add Device. Go over to the Calculator category and then go down to Rescale Signal Calculator and hit Install.
Once that's done, then exit the Manager and go over to Parameters, within the same Setup>Devices menu that the Manager was in. Go to the previously empty Device letter that you assigned the Rescale Signal Calculator to (mine was slot F) and enter in all of the following information:
What this does is make a parameter using the Rescale Signal Calculator that subtracts the Baro PSI reading from the MAP PSI reading, names it Boost and then puts the psi label on it.
Then all you have to do after that is go back to your gauges page and set the signal of whatever gauge you want reading boost to the Rescale Signal Calculator parameter that you've named Boost.
Enjoy your new boost gauge.
Old 04-16-2015, 02:01 PM
Jorge Ortiz's Avatar
Hey i know this is an old post but I am having the trouble with it calculating the boost. I think you have some information missing
turbochargedss2012
09-20-2023 12:17 PM
Sl0wbaltSS
11-21-2018 11:11 PM
01-12-2016 12:01 AM
RaginChopsuey
10-27-2015 01:27 PM
brandon04
10-21-2015 07:04 AM
Quick Reply: Other/Misc: Adding the Boost Parameter to Your Dashdaq
