2.0 LSJ Engine: Airbox modification
#151
hey guys ...ss sc cobalt u seem to be pretty knowledgeable about this mod..but this is to anybody who actully did the mod ..i really want to do this mod but from reading the responses from people who have done it i jus dont want the cel to come on...i went and bought the same filter from pep boys as ss sc cobalt did when u do the first mod if i use that filter, would i have problem if dont disconnect the batt. on the neg. terminal or even if i did disconnect would i still get the cel.....? jus a question
also why dint u have to put oil in the dryflow ? does it have a thicker membrane how is it different then regular air filters
#153
Originally Posted by youngblood
where can i get a dryflo and what is the fitment size or r they all the same
you can order them from jegs, summit,etc about $45
as for the pep boys filter, do not over oil it, keep it way light and let it sit for a day or 2 before you use it after you oil it. the problems with this stuff stems from the oil getting on the MAF wire.
#157
Originally Posted by mastoer
I GOT A CEL WITH THE PEPBOYS FILTER...BUT WHEN I PUT ITON THE OBDll SCANNER IT JUS SAID ERR ..IT DID NT GIVE ME A CODE IMMA TRY THE DRY FLOW
#159
Ss Sc Cobalt ..After I Get The Dry Flow And Put Thet On Would I Have To Reset The Whole System Again OR WOULD I HVAE TO GO GET THE PCM REFLASHED BY THE DEALER MY SS S/C COBALT IS BONE STOCK EXCEPT FOR THE AIR BOX MOD....and That Is The Code I Got Any Input On Y?
#160
#162
with the aem part number 21-2110D does the bottom of the air filter box go back on or do u have to modify it to fit... i know to tighten it u need to put a hole but will the bottom go back on??
#163
#164
i live in winnipeg and if u ever been up here its scary to leave ur air box that exposed lol....if its not water its 10 feet of snow or a blanket of mosquitoes or dust from all the construction i think it would just be the safer bet!
#165
Originally Posted by SS_SC_Cobalt
bottom will go back on if you want, and dont worry so much about the code GM itself said it doesnt affect performance, just annoying
Ya know with that being said I wonder if GM will put out an Update to keep this from being an issue. I mean they at the moment don't have a need or real benefit to do that but I wonder if folks barked often and loud enough something would get done. That is the only thing keeping me from going with an aftermarket intake.
#166
But Hell is due to freeze over then this update should be ready
#167
I have the bulletin here from GM and they are working on it
Great info man! Thanks! Let us know if/when they actually get it done.
#171
I really dont think so but the same thing happened to my friend with his car. Is this happening to anyone else? Also am i throwing the oxygen sensors off and thats why the check engine light goes on?
#173
How do i get the code and where do i get the reflash. Also when installing my filter i didnt put the cover back on the bottom of it that was under the stock filter is that a problem?
#175
