2.0 LSJ Engine: Airbox modification
#201
Originally Posted by SS_SC_Cobalt
sometimes over oiled filters are causing the cel....
hey i got the dry flow fliter and i got a cel about two days ago do u know what p0300 means cause thats the code i got this time...thanks
#202
#203
i have the AEM. its great. I got the CEL like 2 days after i did it. later that day it went away. it came back on yesterday and went away later that day. It isnt an ongoing things so its no biggie.
#204
off topic here i know.. but i checked at murrys and a autozone for the aEm filter and i belive i gave them the right size number but they dont carrie them .. any one know what i should do?
#206
So am I correct by saying this.....
If I buy an Injen CAI and install it myself, then I just unplug the negative battery terminal for 10 mins or so then put it back on and I should never get a CEL ?
#207
#210
get it from the net, better off anyhow....jegs, summit, etc.
Dryflow Air Filter; Replacement; 3.25 in.; Short Neck; 5 in. Element;
Part #: 21-2110DK
$45.10
thats the filter im gonna buy but ss sc the filter is longer then the picture of the one u put in ur car?? any diff? or shouldnt i get it? heres the direct link to the page take a look.. its off the AeM web site.... http://www.aempower.com/ViewProduct.aspx?ProductID=420 well message back if u know what i should do? or if thats ok to buy.
Cody~!
#211
If you'll note... the picture says "representative image"
As thus.... it's not a picture of the real thing... just an image to show you what a cone filter looks like.
I personally used the Spectre filter that was used in the original airbox mod. It was only $25... and has been problem free so far.
#215
ebay special
How wide can you go, this AEM is only $14. Not too clear if this a dry filter or not, it explains washing with AEM solution and then just drying and reinstalling. I thought all dry filters weren't reusuable?
I love filters with the inverted cone in the center, my turbo Camaro just loved 'em with quick spool times.
3' inch opening
Includes 1 Clamp
7 inches long, 6 inch diameter at widest part
Can we get some dimensions form you guys on what will fit back in the box?
Thanks.
B
3' inch opening
Includes 1 Clamp
Thanks.
B
#216
3' inch opening
Includes 1 Clamp
Thanks.
B
3' inch opening
Includes 1 Clamp
Thanks.
B
AEM dryflow is reusable. The pic doesn't look like an AEM to me but I could be wrong.
#217
#218
Heh, its like crack. Get a little, and want a lot more! I pulled the bottom off my box tonight (did a wire-job so the filter will stay in) because I couldn't wait for my dry flow to arrive. Sounds nice, but I want it louder! Come on Mr. delivery guy.
#219
I used the K&N E-1009 and left the bottom of the box off. I have only gotten the CEL on two different days with high humidity after a heavy rain. I found on one of the forums that they do have an update for the computer. I talked to the dealer and they found there was 3 updates for the computer. One being for the CEL showing the engine was running lean. I have not gotten another CEL yet but I can keep you updated.
#220
What can I give to my dealer to have them look up the CEL update? Will that let me run the AEM short ram among other CAI's out there?
#221
after reading on all the issues and views, i just installed my K&N replacement today. looking at yalls views/opnions/advice i made a slight mod to go with everything here.
FIRST-
since i didnt want to mess with a clamp to support the filter to stay on and no holes after the filter what i did was cut the bottom part thats removable. i cut it a little less then half leaving enough for the 2 screws closest to the tire and part of the hump in the middle to keep the filter snug with no chance of it coming off.
SECOND-
i cut the filter box on the side closest to the fender of the car. the tube that goes all the way up and is open at the top, i pretty much just went straight down following it.
if i cold find my camera id take pics.
my question is this, are most of yall keeping the flap/guard on the bottom off or leaving it all on to get the louder sound? or is it load enough with the flap guard all screwed back on?
FIRST-
SECOND-
#222
#224
FIRST-
SECOND-
FIRST-
SECOND-
