Interior: How to change cluster, HVAC control, window and door lock to LED
Old 02-07-2016, 10:41 PM
  #301
Pasierbek's Avatar
This is such a great project to spruce up the interior a bit. I'm working on my Blue LED swap now to contrast against my painted white door lock panels. But one annoying bit is finding the polarity on the PCB! I could not find any markings whatsoever for polarity on the double window switch on the driver's side circuit board. The first time, I soldered it in the wrong way and the LED didn't light, so I switched it around and then I was good. I mean its just a small nuisance but come onnnn lol
Old 02-08-2016, 01:35 PM
  #302
YelloEye's Avatar
You didn't measure and mark before desoldering the bulbs?
Old 02-09-2016, 06:23 PM
  #303
Pasierbek's Avatar
Some LED leads are impossible to get to. Like the power window controls. The LED is soldered in under the power connector.
Old 06-10-2016, 07:09 AM
  #304
CudaJoe's Avatar
Thanks for write up, question
What bulb style should I have used? I ended up using white diffused white LEDs. The HVAC isn't as bright as I thought it would be. I figured white diffused would be best because it shines light equally in all directions. I guess what bothers me is the ac speed numbers don't light up equally
ineedacobaltss
11-07-2015 02:25 PM
agentirons
10-16-2015 02:11 AM
jmelton327
09-26-2015 10:04 PM
09-26-2015 06:44 PM
Coballin13
09-25-2015 08:43 AM
Quick Reply: Interior: How to change cluster, HVAC control, window and door lock to LED
