| Forum Jump | Gallery | Social Groups | VBgarage | Videos | Chat | Link To Us | Decals | Site Map | Contact Us |
| Home | Regional | JOIN US! | Gallery | Rules and FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| How to Guide For step by step “How to” instructions ONLY! |
This is a discussion on How-To: A/F Gauge Install on 2006 Cobalt LS & Supercharged within the How to Guide forums, part of the General category; Vehicles covered by this write-up : 2005-2006 Cobalt LS & Supercharged Installation Duration : 1 hour Skills needed (1 being ...
LinkBack | Thread Tools | Search this Thread | Display Modes |
#1 | ||
__________________
My Car website.
1989 Mazda MX6 - Currently under a lot of construction 2006 Chevy Cobalt LS - RIP 10/2007 |
#2 |
nice how to.. i will be installing my A/F gauge soon just cause thay look cool at night
#3 |
what about putting a new sensor in the downpipe?
#4 |
does this gauge run air fuels from the computer? because unless it does then you signal is fake and you need a wideband
__________________
![]() ![]() Delaware'z fastest saturn! 13.4 @ 105 w/ a 2.2 60ft |
#5 |
That would be a narrowband setup, which is why there isn't any sensor being installed. To install a wideband, it's pretty much the same thing, except you don't tap into that purple wire. You would hook it up to the sensor. You/someone will need to install a place to install the sensor though. It says in the instructions how far from the header to put it, I forget at the moment.
__________________
![]() NGalaxyTimmyo 06 Laser Blue Chevy Cobalt SS/SC Picked up on Sept 27th, 2005 Moded E/T Time: 13.87 at 105.11MPH with a 2.43 60ft Dyno'd at 248.0 HP and 241.0lbs of Torque |
#6 |
May want to throw in an add-a-fuse. Unless you test the circuit after removing the fuse you put the stripped wire to, you only have a 50/50 chance of running a fused circuit to the gauge. If the power wire that runs through the firewall rubs between the steel and rubber boot, bye bye cobalt.
#7 |
Member #: 4146
nice write up, thanks for taking the time to do it and provide good pics of everything. you'd definitely want to put a fuse in that power wire, within 18" from the source. also for the record, this shows a narrowband installation.
__________________
#8 | |
Quote:
From what I've read, the AEM UEGO and Innovate LC-1 widebands can actually use your primary o2 sensor location and relay your narrowband signal back to your wiring harness for you using an analog output. One less sensor to replace and no need to get a bung welded would be the main benefits of doing that, I guess.
__________________
#9 | |
Quote:
#10 |
A quick google search shows that AEM UEGO can emulate your stock rear O2 sensor by adjusting the output from 0-5v to 0-1v. zomghax, you sir, are the &^%$ing man.
#11 | |
Quote:
http://www.hptuners.com/forum/showthread.php?t=2947 A bit of info on the AEM gauge confirming it works the same way, nothing too specific though: http://www.hptuners.com/forum/showthread.php?t=6606
__________________
#12 | |
Quote:
__________________
#13 | |
Quote:
Some other forums that I googled mentioned the capacitor, but it might only be for older models of the UEGO or may have to do with the make/model of vehicle. Hopefully I'll know shortly. |
#14 | |
Quote:
__________________
#15 | |
Quote:
#16 |
Man wish this got the attention back when I was TRYING to find that purple wire. LOL
Circuit will be tested to make sure its fused. I don't want to run straight to the battery due to I don't want it lite up 24/7. So right now its just tied into that fuse. But I'll test the fuse tonight. I believe I have it on the right side, but gotta double check.
__________________
My Car website.
#17 | |
Quote:
#18 | |
Quote:
__________________
My Car website.
#19 |
so are you actully getting real readings or is the gauge jumping up and down?
__________________
#20 | |
Quote:
Just for everyone to know. I checked the fuse and it is correctly ran. The wire is NOT on the hot side it is indeed on the fused side. Do you guys need a video of it to better understand how it functions?
__________________
My Car website.
#21 |
is the signal wire purple or purple with a white strip cause i had a few other people tell me its just purple
__________________
2006 SS/SC Arrival BlueMods: Injen CAI, Magnaflow Cat-Back, Vibrant Header, Ingalls Torque Brace, Sportlines, HP Tuners, DC Strut Brace, B&M STS, #60 Injectors, 2.8 pulley, Dual Pass Option B, Harrop HTV1320 supercharger/80mm pulley Arrived: Diamond pistons, Exedy clutch, Stage 2 Axles, Quaife 6 speed conversion Ordered: JBP Stage 3 Cylinder Head, JBP Tri-flow Cams, JBP Crank Pulley [SIGPIC][/SIGPIC] |
#22 |
It is the purple wire. The purple with the white strip is for the rear 02 sensor.
__________________
Mods: GMPP Touring Cat-Back, CA Cold Air Intake, GMPP Stage 1, CA 3 Gauge Pillar (Autometer Volt, Air/Fuel, Boost), Street Glow Blue Neon Underglow, Engine Accents w/ Paint & Neon, Short Antenna, Tail-light Covers (Matched), Billet Grill, Headlight Yellow Vinyl Covers, Clear Bra, DC Strut Brace.
[IMG] [/IMG] |
#23 |
so this is a noob ?...what will the a/f guage let u do...i know it will show the a/f but how do u adjust it?...the a/f ratio that is
__________________
#24 |
thats what tuning is for.
you adjust it with a piggyback or tuning software like HP Tuners. |
#25 |
ok so you use the purple wire.. here is my problem i cant seem to find my way into the engin bay through the fire wall.. will that same wire be found under the dash in the group of wires that link up to the plug for your ecm
????? -drew
__________________
| Bookmarks |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Installed Boost Gauge (Warning: Long Install Instructions) | ExHondaMan | How to Guide | 29 | 08-08-2006 07:36 PM |
| Info On My Cobalt LS Coupe 2006 | djblass | Appearance | 1 | 02-03-2006 10:56 AM |
| Team Cobalt aims for Championship in sophomore season, five cars compete in opening G | JonyyB | Front Page News | 5 | 01-30-2006 09:22 PM |
| Chevrolet Cobalt SS Supercharged Coupe Project | zinner | Front Page News | 8 | 06-03-2005 03:23 PM |
| 2005 Chevrolet Cobalt SS Supercharged Coupe | JonyyB | Front Page News | 0 | 11-11-2004 07:59 PM |
