All Engines: How-to Install header and downpipe
Old 03-28-2009, 08:48 PM
DynamikGT's Avatar
Will be following this when my header and dp get here wednesday. Great write up!
Old 03-28-2009, 09:16 PM
OBZ
OBZ's Avatar
Right on thanks man! Let me know how it goes!
Old 03-30-2009, 01:30 AM
koch1ar's Avatar
great write up
Old 04-02-2009, 07:53 PM
NexTnmE's Avatar
Great How-To. Thanks for spending the time to do it.
Now a question.... I'm going to be installing the JBP Vortex header onto my stock downpipe , and GMPP exhaust. The header did not come with the three double-headed bolts you mentioned. Are the bolts from the stock mani re-usable? Or should I buy three nuts and bolts?
Any help would be great.
Old 04-02-2009, 08:16 PM
OBZ
OBZ's Avatar
Not a problem man! I'm glad ppl are getting use out of it!
Are the three holes on the header threaded? If do you can use the stock bolts, but I'd still probably go out and buy new ones. If you already spent that much on the header, whats 3 bucks for a few bolts right? If they are not threaded just go out and buy 3 nuts and bolts
Old 04-02-2009, 08:29 PM
NexTnmE's Avatar
The holes on the JBP are threaded. Sweet. Do you think I'll even be able to get the original bolts out tho? Whatever tho...if they don't come out...I'll hit up home depot...
Old 04-02-2009, 08:31 PM
OBZ
OBZ's Avatar
Yeah man just take that header with you, and make sure you get the right size. Also make sure before you try to remove any bolts, to douse that **** with some penetrating fluid! It really helps a ton!
Old 04-02-2009, 08:33 PM
NexTnmE's Avatar
Yeah. I'm gonna hit up the store before I install that biatch. Wanna do it right the first time. I'll post up some pics once I'm done Thanks again!
Old 04-02-2009, 08:43 PM
OBZ
OBZ's Avatar
Good man!
Not a problem bro! Good luck on the install! Can't wait to see pics!
{EDIT} I just remembered that the 3 bolts for the DP/manifold are actually stuck in the manifold. So yes, you would have to get new bolts regardless
Old 04-02-2009, 08:49 PM
SlyderRE's Avatar
question, do i need a new mani gasket? only got 17k miles
Old 04-02-2009, 10:04 PM
  #36
NexTnmE's Avatar
Yeah, you should probably get one...play it safe son!
Old 04-02-2009, 10:05 PM
  #37
OBZ
OBZ's Avatar
You should be fine with the stock gasket. But most headers come with new gaskets.
Old 04-02-2009, 10:09 PM
  #38
NexTnmE's Avatar
I'm thinking I'm gonna get a new gasket for the d/p-to-catback just in case...its been 20,000 hard miles...
Old 04-02-2009, 10:10 PM
  #39
Black SS/SC 06's Avatar
You are better off replacing a used gasket. They aren't that expensive anyways.
Old 04-02-2009, 10:45 PM
  #40
OBZ
OBZ's Avatar
Yeah I'm sure it would be fine, but they are pretty damn cheap anyways so might as well
Old 04-03-2009, 07:58 AM
  #41
SlyderRE's Avatar
aite guys thanks, and great write up. will follow when i do my header
Old 04-03-2009, 11:23 AM
  #42
OBZ
OBZ's Avatar
Your welcome and thank you! LMK how it goes!
Old 04-24-2009, 10:33 PM
  #43
stormy42's Avatar
great write up. i will b using this on sunday wen i put my hearder and downpipe in.
Old 04-27-2009, 01:07 AM
  #44
OBZ
OBZ's Avatar
Thanks! how did it go?
Old 04-27-2009, 05:48 PM
  #45
outlite's Avatar
when i did this i replaced my stock header studs with bolts the same size... this made it 3 times easier to install. i would sugest running down to the store and picking up a set to make your life easyer.
Old 04-27-2009, 11:43 PM
  #46
stormy42's Avatar
looks and sounds great. thanks to ur write up the install was easy.
Old 04-28-2009, 12:52 PM
  #47
OBZ
OBZ's Avatar
Good to hear man!
Old 04-29-2009, 10:00 PM
  #48
ruhland287's Avatar
That looks suprisingly easy
Old 05-01-2009, 07:58 PM
  #49
OBZ
OBZ's Avatar
^^ It really is.. Just kinda PITA to get to some bolts.. Many PPL are afraid of this project for no reason!
Old 05-13-2009, 05:07 AM
  #50
averagewhiteboy's Avatar
Will be using this in a few weeks. How will I hook my AFR sender to the 02 sensor? It's just a narrowband, but the readout will be more realistic from the 02 as compared to the under-hood wire..
Quick Reply: All Engines: How-to Install header and downpipe
