Appearance: How-To: Install LED Taillights W/ Resisters (Coupe)
Old 02-22-2012, 03:23 PM
mkulrey13's Avatar
Arrow How-To: Install LED Taillights W/ Resisters (Coupe)
This How-To will show you how to remove your taillights install a resister and install your new LED Taillights. Coupe Only! Sedan taillights remove almost the same way but a tad different!
Tools Required:
11mm Socket
10mm Socket
Socket Wrench
1) Open your trunk and remove the black nut that holes your net in place
2) Peel back the carpet and your left with 3x 10mm nuts. Take your 10mm socket and screw all 3 bolts.
3) Slowly wiggle your taillight out and twist the bulb socket out of the headlight
4) Now its time to wire up your resister, Take one wire from the resister and splice it into the Green OR Yellow wire on the socket. For some reason my passenger side was green and drivers side was yellow. Take the other wire on the resister and splice it into the black wire on the socket. I used quiktaps but you can use what you'd prefer.
5) Now mount the resister where its out of the way. I used double sided tape and stock it inside right next to where the tail light mounts. Make sure nothing is touching it as it gets hot!
6) Connect your LED tail lights to your OEM socket. I have the "K2Motor" tailights so the leds plug into the socket then the socket twists into the tail light the same as OEM.
7) Reinstall the same as you removed them. Some taillights may require you to reuse the OEM gasket. These did not.
8) Now its time to install the reverse tail lights mounted on the trunk. Start by removing the cover over them and taking off the 11mm speed nuts. Once the nuts are removed you will see tabs that keep the taillight in place. Move those and take the tail light out.
9) Now with it removed my taillights required me to reuse the old gasket. Simply peel it off slowly. Its very sticky so you will have no issue getting it to stay on your new taillights. Also take note on the raised parts of it and make sure its put on the new tail lights the exact same way.
10) You may need to make your speed nuts smaller. Simply using a vice you can crush them ever so slightly to make them fit the taillights.
11) Reinstall the exact same way you removed them and be on your way with some new taillights!
Old 02-22-2012, 04:23 PM
Vtec Rep
BPacak's Avatar
nicee
Old 02-22-2012, 04:27 PM
1LowLS's Avatar
Looks like a nice clean install.I love mine as well.Gives the car a completely different look
Old 02-22-2012, 04:33 PM
great how to, one question! where do you get the resistors?
mkulrey13's Avatar
PM us we sell them!
Old 02-22-2012, 04:52 PM
uhh... pmd? can't find such resistors on ur site
Old 02-24-2012, 01:08 PM
Got Bewst?
Bluelightning's Avatar
Just a note for when people take off the foam from the reverse lights, that black sticky silicone is stringy and was all over the place making a huge mess when I changed mine. But I found putting the reverse lights in the freezer for a bit and getting the silicone cold allows it to come off nice without making a mess. I see yours came off real clean Mike. Lucky guy lol.
Old 02-24-2012, 04:07 PM
mkulrey13's Avatar
I pealed it very slowly.
Old 03-16-2012, 07:35 PM
R3AP3R's Avatar
sorry im a noob about this but.. what is the resister for?
Old 03-25-2012, 11:49 PM
iToastie's Avatar
Prevents it from hyper flashing.
the wattage of LED's is lower than the normal bulbs, so the car thinks the bulb is burnt out, causing your flashers to blink hella fast to alert you it's burnt out, this will stop that
Old 04-06-2012, 06:49 PM
nobody2u's Avatar
Sub'd! Thanks!
Old 04-12-2012, 01:32 PM
KitanningCobaltPa's Avatar
u
L U
n
Old 04-12-2012, 01:34 PM
lolwut^^^
hey just wanted to thank you op for the thread and hook up, followed this how to and i'm blinking like normal now! very easy! thanks!
only 'complaint' is the buttsplicers or w/e connectors the kit provided... didn't rly work. so i soddered instead.
Old 09-15-2012, 08:35 AM
fullmetal289's Avatar
perfect guide OP, subd...
i have a coupe and the exact same led taillight kit as you, so this is PERFECT for me, thanks!!!
EDIT: i noticed you added additional black wire to each end of the resistor, what gauge is that?
Old 09-28-2012, 08:44 AM
esink's Avatar
good guide. thanks.
Old 10-02-2012, 02:41 PM
CannonBalt's Avatar
I have LED tails, I like the Hyper blink. It's different
Old 10-13-2012, 01:22 PM
terrinb's Avatar
Does anyone have any suggestions on where to buy taillights that have both reverse lights and blinkers?
Old 10-15-2012, 07:17 PM
LamboW9's Avatar
I wish i could find someone to sell me just the inner tails.
Old 10-15-2012, 07:25 PM
AWD > FWD
TommyP's Avatar
ebay
Old 10-15-2012, 07:58 PM
LamboW9's Avatar
^^i've looked. i want the inner ones like mk has in his OP. i'll look again but haven't had any luck findin em
Old 10-30-2012, 08:12 PM
White10turboSS's Avatar
Old 12-26-2012, 02:22 PM
in some states it is illegal. i kinda think the hyper blink is lazy and trashy looking.. the slow blink means someone took the effort of doing this to make it legal.
Old 12-28-2012, 06:56 PM
cobalt523's Avatar
Only one resistor is needed? Or one for each side? An how about if I have switchbacks in the front? What ohm/W is needed?
Old 12-28-2012, 07:31 PM
EmperorJJ1's Avatar
one for each LED bulb you have switchbacks included if they are LED.
Solaris99
28
03-15-2017 01:22 PM
dennis69
10-20-2015 07:39 AM
justinchinn
10-02-2015 12:18 PM
Tupp
09-30-2015 08:18 PM
Delta coupe
09-30-2015 08:11 AM
Quick Reply: Appearance: How-To: Install LED Taillights W/ Resisters (Coupe)
