| Forum Jump | Gallery | Social Groups | VBgarage | Videos | Chat | Link To Us | Decals | Site Map | Contact Us |
| Home | Regional | JOIN US! | Gallery | Rules and FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| How to Guide For step by step “How to” instructions ONLY! |
This is a discussion on How-To: Oil Pressure Install on 2006 Cobalt LS within the How to Guide forums, part of the General category; Vehicles covered by this write-up : 2005-2006 Cobalt LS Installation Duration : 1 hour Skills needed(1 being least and 10 ...
LinkBack | Thread Tools | Search this Thread | Display Modes |
#1 | ||
__________________
My Car website.
1989 Mazda MX6 - Currently under a lot of construction 2006 Chevy Cobalt LS - RIP 10/2007 |
#2 |
Cool mod. Why they thought the Cobalt shouldn't have proper gauges is beyond me.
Maybe a temp gauge should be next? (Yes I know its available in the DIC but I'd much rather have a gauge) |
#3 |
Next gauge is my nitrous gauge beside the shifter. I may put two there on the steering column...Volt and Temp I guess. That is later on.
__________________
My Car website.
#4 |
Teflon tape? Why not use RTV form a gasket? Just askin, not bashin. I've always believed that teflon will break down eventually and one leak, but two a piece of that swimming around in your oil *shudders*.
#5 |
I'll get ya, 'cuz I'm the
When selecting a power source by tapping an existing circuit, know what you are doing. One side of the terminal is hot. If is tap that side, you are not fuse protected unless you use a separate in line fuse. Also, be sure you select a properly switched circuit (one that turns off with the key).
__________________
#6 | |
Quote:
__________________
My Car website.
#7 | |
Quote:
Oh yeah another tip leave the first few(that start) threads clean of the stuff. I do it so much I guess out of habit it doesn't even register.
__________________
My Car website.
#8 |
where is that port you screwed the oil pressure guage into?
#9 |
good mod. good mod. i wonder if the LE5 has the same setup.
#10 |
I have a tough time getting my bearings on the last two pics....like where in the engine it is...
Any way someone could post another pic that provides a better point of reference....? |
#11 |
same with me...i think it's the drivers side of the motorbetween the motor and the computer. i think i found the plug BUT there is no possable way i can get a pair of pliers there to get that plug off. i think i might try and use a "T" joint off of my stock location. which you basically need to be Hudini to get to (it's under the supercharger and just to the bottom left of the oil filter and you can't see it and can barely touch it from the top). i think i have a plan of attack...i'm going to remove the starter to get a clear shot at it (i hope). i'm doing this on saturday so i'll let you guys know how it goes!
#12 | |
Quote:
i would agree... if you look in the fusebox pic, you can see the red wire off to the side and it running down to the engine. |
#13 | |
Quote:
#14 |
Do you think that the oil pressure sending unit is the same at the 2.2L
#15 | |
Quote:
This How-To and pictures were made referring to the 2.2L. I own a 2.2L.
__________________
My Car website.
#16 |
would this be the same for a 2.4?? and also what is the diff between mechanical and electrical and do they both work the same for the oil pressure gauge? thnx for the help!
#17 |
anyone kno?
#18 | |
Quote:
__________________
My Car website.
#19 |
I got the Autometer Sportline gauge from summit (ATM-3327) But the biger adapter on the sender it too big. Wtf I need help i don't understand this. I beleive its 1/8 inch going to 1/4 inch. but the threading in the sender is just a litttttle too big. Help please.
#20 |
Im doing my own install and I thought I could get some more pictures for those who want to do this themselves. Im waiting on my gauge pod from CA, but I have just received all my parts from Summit racing. Im installing a digital voltage and oil pressure gauge. (By the way, these gauges are like $30 each, and appear to be great quality. If you want to get gauges go with these summit gauges, they are great digital gauges.)
![]() As you can see in this picture, the 2 gauges, the oil pressure sending unit, and the Autometer adapter you need. Ill post more pictures when I install it and try to get a better angle of the sending unit installed. |
#21 |
Supporting Vendor
i just installed my oil pressure gauge from this how-to. It was a very good how-to. as for gauges i went with autometer shortsweep c2 electric. i went with oil pressure volts and water temp. got them on ebay for about 50$ each.
__________________
![]() 1 of 118 White Cobalt SS Turbo Coupes Ever Produced! Need HIDs? PM me |
#22 |
i have the autometer mechanical....im sure someone else here does too....
the adapter on the sender appears to be to small i havent tried it yet but thought i would ask before i tried. So.... 1. i would assume but i should install my mechanical sender in the same place right? 2. does the autometer mechanical adapter fit that spot? i dont know where else i would/could install it anyways. thanks for the help...
__________________
#23 |
bump for this gauge install. i needed this to but hell will it work on a 07 lt2. i know that last one got me in the write direction...
__________________
![]() ![]() Central Pennsylvania Trifecta Dealer |
#24 |
bump i have a mechanical too... but no idea where to put it....
the plug is a completly different thread
__________________
#25 |
do exhaust shops installed wideband and a/f gauge???
__________________
2009 RR Civic Si- Injen sri, 70mm tsudo cat back, Cobb tuning knob
2005 Srt-4- well let's just say second time around ....failed 2007 R.Yellow 2.4 SS on boost- Let's not go there after 8/31/09 accident |
| Bookmarks |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| How-To: A/F Gauge Install on 2006 Cobalt LS & Supercharged | Blackout06LS | How to Guide | 119 | 10-23-2009 02:06 AM |
| FAQ - Superchargers | plyboy-illest | 2.0L LSJ Performance Tech | 32 | 04-29-2009 06:46 PM |
| AutoWeek review - Cobalt SS | JonyyB | Front Page News | 19 | 03-27-2006 12:56 PM |
| Detailed Specs for 2006 Cobalt | Firenze | Front Page News | 60 | 07-25-2005 12:17 AM |
| 2006 Cobalt Colours | Firenze | General Cobalt | 29 | 05-09-2005 06:26 PM |
