2.0 LNF Engine: How To: Valve Gunk/Coking Removal
Old 11-19-2013, 12:30 PM
Shanedude's Avatar
Originally Posted by Wired
Ya I did. Told it is a maintenance issue, not a warranty one.
Sorry to hear that. I would hate to pay that bill. I had my tranny serviced @75k, it started to go 5k later and I got it replaced brand new no hassle. Come to Canada mate we pay more for almost everything but the people are fair!
Also that much build-up on such a young engine? I will have to find someone who can get this done for me I am probably way overdue.
Old 11-19-2013, 01:01 PM
Wired's Avatar
Funny thing, my car is a Canadian model!
I did not have tranny issues that was another guy.
My engine did have a bad turbo and a previous owner that I think may have beat on it. Those are the only things I can think of.
Old 11-19-2013, 01:34 PM
Shanedude's Avatar
**** my bad got confused. Ima sub this and thank you for putting the time to post it up. I will need to do this next year for sure. I haven't noticed any symptoms yet but it must be rough in there.
Old 11-19-2013, 02:15 PM
CudaJoe's Avatar
great write up! I will have to give this a shot one day when I have the time
Old 11-19-2013, 02:23 PM
umrdyldo's Avatar
10 hours of beer is gonna cost more than the tools to do this.
Old 11-19-2013, 02:35 PM
dcrep06's Avatar
Originally Posted by umrdyldo
I would be beating heads if it didn't get covered when stock.
Trust me I was about to.
Passenger belt tension sensor. Wires become stressed and start to acquire a open circuit. Turns airbags off. Light and message on the DIC comes on over and over. Seems like a safety problem due to the airbags turning off and my eyes coming off the road over and over when the light comes on.
https://www.cobaltss.net/forums/prob...ir-bag-299167/
One thing after another!
I'd also like to say that the valve cleaning has not totally made my morning starts ups always smooth. I still get some hiccups now and then. Plus now that my snow tires/wheels are on I can't try WOT or I spin instantly so I have no way to see if the top end misfires went away,
I just started getting the passenger airbag needs service a little while ago smh.
Truth^^^^
Old 11-19-2013, 05:57 PM
seeyaass's Avatar
Now you were able to blast when the valves were shut and you weren't worried at all about any going into your motor?
Old 11-19-2013, 06:18 PM
Powell Race Parts's Avatar
SMH! Read the how to!! the valves have to be closed. BUT that said, the media is wood and any stray fragments will burn away harmlessly in combustion.
Old 11-19-2013, 06:28 PM
dcrep06's Avatar
Lol^^
Old 11-19-2013, 06:34 PM
714ionredline's Avatar
Dumb question but how do you close the valves? Didnt read any of that on the how to.
Old 11-19-2013, 06:35 PM
  #36
rotate the motor. or you can rotate the car. take your pick. dumb answer.
Old 11-19-2013, 06:42 PM
  #37
seeyaass's Avatar
I obviously read the whole how-to.... Which is Why I said "when the valves were shut you weren't worried at all about any going into your motor?"
Simply asking if he felt confident that nothing would have went in the motor.. Wasn't sure if a few specs could have got in and it would be harmfull. Sheesh.
READ. Lol put in 4th spin the tire.
Old 11-19-2013, 06:50 PM
  #38
ItalianJoe1's Avatar
That's the wonder of walnut shell media, it's hard enough to remove crud but safe for the engines. Gotta love it.
It's also easy to put a socket on the crank pulley and just turn the engine over a half turn or so.
Old 11-19-2013, 07:23 PM
  #39
seeyaass's Avatar
Nice I don't know what mine looks like in there but definitely gonna plan on doing this over winter.
Old 11-19-2013, 07:28 PM
  #40
they look awful lol then you can buy my upgrade once they are clean. the upgrade helps keep it nice; wont do diddly to get rid of the coked oil already there. And if the piston rings and lands are damaged thats a whole other story
Old 11-19-2013, 07:51 PM
  #41
seeyaass's Avatar
What upgrade do you offer Powell? And lord don't jynx me I believe my rings are fine as of right now.
Old 11-19-2013, 07:59 PM
  #42
seeyaass's Avatar
And question.. What causes these valves and ports to gunk up so bad like that?
Old 11-19-2013, 08:21 PM
  #43
dsp86's Avatar
dealership took care of mine under warranty..they don't have a choice if the cel comes on..
Old 11-19-2013, 09:09 PM
  #44
SSSnoop's Avatar
Why does it happen? Dry intake, plus oil blowby from the turbo, plus a little dust getting past the air filter equals crud. Normal fuel injection is above valves, meaning you get a solvent wash with each injection - doesn't happen in DI's where the fuel enters below-valve.
Got a question on this - did you do anything to make sure you didn't have any walnut crap stuck up the crannies at the tops of the valves? Did you spritz anything up there to ensure you didn't have any renegade solids, or did you just assume/hope/expect the stray bits would just pop into the cylinders after a few cycles?
I haven't checked my 09, and I was thinking a few seafoam treatments are in order - and maybe something like this if I can't seafoam/5th injector and stay clean enough.
Great how to, either way, and great job with the pics - very clear!
Old 11-19-2013, 09:22 PM
  #45
Wired's Avatar
Trust me. Seafoam cannot touch this stuff. It is on there hard and thick (lolz). If you can't trust me then trust John Powell. A 5th injector would help prevent it but not remove effectively what is already there.
I used a scraper tool and lots of compressed air to try and get the most I could from the valve seat area (including the hidden side to the front of the car which I feel most people would miss as you can't see it. I scraped a ton of crap out of there.) as well as the valve stem area. I am sure I missed some as you cannot remove all of it. Any that does get into combustion is harmlessly burned being that it is combustible organic material (wood).
Old 11-19-2013, 09:49 PM
  #46
Please read the main LNF valve gunk thread it will explain the whys and wherefores. This thread is the how to.
and seafoam ? gets in your mouth when you surf.
Old 11-19-2013, 09:50 PM
  #47
crap another. Please read the LNF valve gunk thread very well started and very well explained. Props for wired for the how to.
props to anyone who goes read the other thread
Old 11-19-2013, 09:53 PM
  #48
https://www.cobaltss.net/forums/2-0l...e-gunk-282355/
gone in 10 secs did a good job with this thread. sssoop read the first post....
Old 11-19-2013, 11:27 PM
  #49
seeyaass's Avatar
Powell what part do you offer to help this after it's cleaned?
Old 11-19-2013, 11:38 PM
  #50
Spawne32's Avatar
Before i cry myself to sleep tonight for having read this, did you really walnut blast your cylinder head ports with the intake valves OPEN? Did the car even run afterwards?
Quick Reply: 2.0 LNF Engine: How To: Valve Gunk/Coking Removal
