Forum Jump Gallery Social Groups vBLive Garage Register Now Videos Link To Us Store Site Map TSBs
Cobalt SS Network Forums
The Cobalt SS Network is the leading resource for all Chevy Cobalts and related Delta
platform cars. Registered users do not see the above ads. Please Register - It's Free!
Vendor Forums
Go Back   Cobalt SS Network > General > How to Guide
Sign in using an external account
Register Forgot Password?
Home Regional All Albums   FAQ Members List
- New threads must be approved by mods before they are displayed.
LinkBack Thread Tools Search this Thread Display Modes
Old 10-08-2006, 10:55 PM   #1
Member #: 6686
Images: 34
Check out my gallery  Check out my vbgarage
Installing Rear Speakers and Removing Rear Deck
Since nobody has a good how to on this, I decided to take my car apart and take pictures along the way, enjoy.
Step 1: Pull the release tabs for the rear seats
Click the image to open in full size.
Step 2: Pull out the 2 pop in plastic tabs
Step 3: Remove each side’s individual C-Panel (By simply slipping your fingers in on the top and pull straight out, they are secured on by a plastic wire that is just there to hold them there in place, you can move the panel of your way and tuck it under the seat belt if you want.
FYI: Watch out for the rear defroster units, make sure not to hit those off when taking the panel off.
Step 4: Remove the plastic cover behind each headrest and unbolt the two bolts securing them
Step 5: You should now be able to lift the rear deck enough to work underneath and access the rear speakers (don’t worry if you bend it, when you put it back down and put everything back together it will return to its original form.
Here are the speaker wire colors for the base cobalt system:
LF Speaker +tan / -gray
RF Speaker +lt. green / - dk. green
LR Speaker +brown / - yellow
RR Speaker +dk. blue / - lt. blue
TIP: When putting the C-Panels back on, make sure you align it up with all the indents along the side (see picture above) do this before you pop the panel back in place!
Okay So now replace your speakers and put everything back in reverse order and enjoy.
__________________
05 Slobalt (Blacked Out) ( Sonic )
Pioneer DEH-P9800BT - Pioneer GM7200 - Alpine SWE-1242 12' - Alpine SPS-69C3
Infinity Reference 6010cs - Audiobahn A6004V - AEM CAI - Pioneer CD-IB100
Progress Springs - DC Sports Front Strut Bar
Xavipheus is offline   Reply With Quote
Old 10-08-2006, 11:50 PM   #2
Points: 20,629, Level: 90
Points: 20,629, Level: 90 Points: 20,629, Level: 90 Points: 20,629, Level: 90
Level up: 56%, 221 Points needed
Level up: 56% Level up: 56% Level up: 56%
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Member #: 8925
Images: 2
Send a message via AIM to HunterKiller89 Send a message via MSN to HunterKiller89
great write up
__________________
Barbados Blue Metallic '04 GTO M6 | Kooks Signature Series Long Tube headers | 3.91's
Black '06 Cobalt LS Auto: Supercharged 265 bHP
| GMPP Exhaust | Smoked Taillights | 5% rear, 15% front | Black Projectors | 18x8 Black Kyowa rims | Nexen P3000 tires | Auto Transmission Mounts | Koni Front/Rear Struts | Sportlines | 10k low/6k high beams | ZZP Mid-Length Header/DP combo | AEM UEGO | Black/Red Insert SS Seats, Door Panels, and Trim Pieces | High Rise Spoiler | M62 Blower | ZZP Heat Exchanger | Option B | Red Mech. Boost Gauge | Dual Red Interceptors | TTR Rear Sway Bar |
HunterKiller89 is offline   Reply With Quote
Old 10-09-2006, 12:43 AM   #3
Member #: 9009
Images: 16
Send a message via AIM to shortyhend2004
haha u jus made my job easier now i jus need to find that damn rattle!!
__________________
shortyhend2004 is offline   Reply With Quote
Old 10-11-2006, 02:09 PM   #4
Points: 6,675, Level: 53
Points: 6,675, Level: 53 Points: 6,675, Level: 53 Points: 6,675, Level: 53
Level up: 63%, 75 Points needed
Level up: 63% Level up: 63% Level up: 63%
Activity: 0%
Member #: 1697
Try not to pull the rear panel towards the front toooo much or you will break off the clips that hold the rear of the panel to the base of the window. I done mine that way on my Yellow one when I changed out my speakers now it has a bit of a rattle to it. Those clips are not replaceable either. they are heat staked on.
__________________
2007 Cobalt SS/SC Red His
Graphite leather w/ red inserts heated | LSD | sunroof | 6 disc
2008 G6 GT Convertible White Diamond Tricoat Hers
Light taupe leather w/ graphite inserts heated | 3.9L| FULLY loaded
fr33k is offline   Reply With Quote
Old 10-14-2006, 02:09 PM   #5
Points: 7,962, Level: 60
Points: 7,962, Level: 60 Points: 7,962, Level: 60 Points: 7,962, Level: 60
Level up: 6%, 188 Points needed
Level up: 6% Level up: 6% Level up: 6%
Activity: 0.1%
Activity: 0.1% Activity: 0.1% Activity: 0.1%
Member #: 6913
Images: 11
Yea I broke one of mine too and I got the lovely rattle now. Any ideas on how to fix it? Maybe some foam tape at the back? Or just hope there is a cobalt at the wreckers with one intact...
06Pursuit is offline   Reply With Quote
Old 11-03-2006, 05:30 PM   #6
Member #: 8968
one little add...if you work your way around the rear deck and undo all the click you can slide the rear deck down the seat belts...and its totally out of your way.
__________________
"Speed kills, so buy a Honda and live FOREVER!"
"Real men race from digs"
PayJ is offline   Reply With Quote
Old 11-04-2006, 08:51 PM   #7
Member #: 6686
Images: 34
I didnt see any clips, hopefully I didnt break mine
__________________
Old 03-04-2007, 01:38 PM   #8
Member #: 14500
Great write up, but no pics. I'm gonna use this to upgrade the speakers in my new 07 2.2
nexus77241 is offline   Reply With Quote
Old 03-04-2007, 01:44 PM   #9
Member #: 6686
Images: 34
Shit, I cant find them, sorry man, I should have uploaded them here and not my old server. But w/e its pretty straightforward when you take it apart, if you need any help let me know
__________________
Old 03-04-2007, 02:02 PM   #10
Member #: 14500
Quote:
The speakers are 6x9? I've been reading on here that its too expensive to replace stock radio (due to extra parts needed) so I'm just gonna do the speakers for now.
__________________
2007 Cobalt 2LT
Stock for now.... Basic mods coming ASAP
Old 03-04-2007, 03:11 PM   #11
Member #: 6686
Images: 34
Yeah the rear speakers are 6x9, fronts are 6 1/2
__________________
Old 03-04-2007, 08:08 PM   #12
Member #: 14500
First thing I gotta do is pop out those small covers on the front when I lower the seats, and then just unscrew the headrest covers? Thats it? I've had the car for 4 days and have not had the chance to look at it. I did see some Alpine speakers at BB for 114.99
__________________
2007 Cobalt 2LT
Old 03-04-2007, 09:53 PM   #13
Member #: 6686
Images: 34
Quote:
yep thats it
__________________
Old 03-16-2007, 10:04 AM   #14
Points: 35,494, Level: 100
Points: 35,494, Level: 100 Points: 35,494, Level: 100 Points: 35,494, Level: 100
Level up: 0%, 0 Points needed
Level up: 0% Level up: 0% Level up: 0%
Activity: 7.8%
Activity: 7.8% Activity: 7.8% Activity: 7.8%
Award-Showcase
Member #: 10015
Images: 298
Send a message via AIM to EmperorJJ1 Send a message via MSN to EmperorJJ1
none none
any updates on the pics?
__________________
My Sale Refs Dual Alternator Setup Carbon Fiber Door Pods
Quote:
Originally Posted by dragon daddy
My advice: If you are serious about reducing noise in the vehicle, use Second Skin products. If not, don't spend the money and add the weight and turn you music up a little louder.
EmperorJJ1 is offline   Reply With Quote
Old 03-16-2007, 08:59 PM   #15
Member #: 6686
Images: 34
No, sorry there gone
__________________
Old 03-29-2007, 12:19 AM   #16
Member #: 7871
i fixed the rattle with 2 calculus textbooks that i placed up on the deck. i just take em out at the track!
__________________
---2005 Victory Red SS/SC---
---AEM Intake---Ingalls "Stiffy"---TAG 2.86" pulley system---Siemens Flow Matched 60lb injectors+harness---NGK 1 step colder plugs---GM stg. 2 belt---TAG Tune---2.5" C-A Downpipe---ARK N2 Exhaust---TENZO R springs---Angel HID Halos---40,000 miles and counting--- Born Newfie Moved To Florida
AdamRedSS is offline   Reply With Quote
Old 03-29-2007, 08:34 AM   #17
Member #: 13487
Images: 1
Send a message via AIM to halo
Quote:
You could also just try sticking towles underneath it. I had done the book thing for awhile, then used towels underneath it. Worked perfect.
__________________
halo is offline   Reply With Quote
Old 10-04-2008, 04:15 PM   #18
Member #: 15517
Images: 2
Send a message via AIM to Sanat
Just what I need to know thanks.
__________________
Sanat is offline   Reply With Quote
Old 10-09-2008, 11:33 PM   #19
Points: 6,584, Level: 53
Points: 6,584, Level: 53 Points: 6,584, Level: 53 Points: 6,584, Level: 53
Level up: 17%, 166 Points needed
Level up: 17% Level up: 17% Level up: 17%
Activity: 0%
Member #: 19852
Images: 53
Send a message via ICQ to warrenb213 Send a message via AIM to warrenb213 Send a message via MSN to warrenb213
with the deck lid off fill any hole that goes to the trunk with like...soft but firm foam. also you will see two sets of wires that get grounded on the passenger side. put some foam under these to support them from shaking too much under bass excursion. on the sides you can reach around and feel u around and you'll notice it's hollow. put some foam up in there too. after u install your 6x9's and your putting the deck back, you'll see directly in the center underneath a black foam block already attached. put some towels under it. about half an inch of more worth. it should be ever so slightly flexing up. ensure the side "clips" of the rear deck are latched firmly to the sides. now get like 5 rubber pegs(clear preferrably) and place them between the rear deck and the rear glass firmly.
now go into your trunk, and fill the remaining open truck holes which lead to the rear deck.
shazzam. poor mans way. lol
__________________
2007 Cobalt LS-L61-5 Speed - Original Modifications:Custom CarPC,Painted Mirrors,Plugged Keyholes, Porsche LED modTrifecta:1st 07 CobaltTTR:Injen CAI,EBC Rotors/BrakesCA:2.5" XTC Downpipe w/CatNEA:Tsudo ExhaustModern Performance:LED Tail lightsGM:LNF FE5 Springs/Shocks,2.4 mani,Low Rise Spoiler,Armrest ModTommy's Window Tint: 35% tintPowell Race Shop:Stage 2 Rotated MountsAmericas Tire:18" Enkei GF1's w/ 225/40/18 Conti Extreme CompactSonic Electronix:Hifonics Zeus 4408, Hifonics 1206D, Infinity Kappa 62.9i, Infinity Kappa 693.9i,12" Type-R
warrenb213 is offline   Reply With Quote
Old 10-09-2008, 11:35 PM   #20
Member #: 22803
Images: 1
Send a message via AIM to YELLOW_REVOLUTION
__________________
2008 Revolution Edition
YELLOW_REVOLUTION is offline   Reply With Quote
Old 12-16-2008, 05:38 PM   #21
Member #: 29031
nice write up... just finished putting in my new rear speakers... thanks a lot
TripMasterMatt is offline   Reply With Quote
Old 12-16-2008, 05:40 PM   #22
Points: 9,477, Level: 65
Points: 9,477, Level: 65 Points: 9,477, Level: 65 Points: 9,477, Level: 65
Level up: 43%, 173 Points needed
Level up: 43% Level up: 43% Level up: 43%
Activity: 0.2%
Activity: 0.2% Activity: 0.2% Activity: 0.2%
Member #: 26691
Images: 51
Send a message via AIM to ilovecars
this needs pics. cuz i had one hell of a time getting mine out. ever actualy got it out.......
__________________
ilovecars is offline   Reply With Quote
Old 12-16-2008, 05:41 PM   #23
Points: 3,969, Level: 40
Points: 3,969, Level: 40 Points: 3,969, Level: 40 Points: 3,969, Level: 40
Level up: 10%, 181 Points needed
Level up: 10% Level up: 10% Level up: 10%
Activity: 0%
Member #: 32439
thats all im seeing
__________________
Mods: Debadged, JDM CAI, Rims & Tires, Tinted Tails, Cat Back Exhaust Coming soon: Tint, Rear Sway Bar, HIDs, lowering Springs...
Team Havoc is offline   Reply With Quote
Old 12-16-2008, 08:49 PM   #24
Activity: 0%
Member #: 19852
Images: 53
guys lol c'mon it's not rocket science here lol.
next time i go in there i'll take some pics. won't be awhile though, as portland is kinda under ice/snow. lol
__________________
Old 12-16-2008, 10:49 PM   #25
Activity: 0%
Member #: 32439
i figured it out pretty easy
__________________
CobaltSS
Chevy Cobalt
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Interior: How to remove and install door speakers khan4rtist How to Guide 31 04-27-2009 11:09 AM
door panels and rear deck speaker replacements Kemo Electronics, Audio, and Video 20 10-16-2006 12:19 AM
Just replaced my back speakers and bad news Xavipheus Electronics, Audio, and Video 57 09-28-2006 10:18 PM
Chicagoland May Meet Planning Halfcent Mid Central 118 05-10-2006 05:09 PM
6x9 speaker removal z3balt Electronics, Audio, and Video 12 01-16-2006 11:56 AM
vBulletin copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Admincp backup
