A quick HOW TO on installing the RPD(UAF)
Old 12-20-2010, 04:49 PM
  #101
rukkee's Avatar
I don't understand why people would wrap up so much money in a RPD when you can buy a dashdaq that will let you watch over 800 PID's for 600 bucks.
Old 12-20-2010, 04:56 PM
  #102
SS-Performance-RS's Avatar
Originally Posted by Stamina
Glad you tried this and verified.
I would've figured that switching it to Imperial on an '09+ and then moving it to the '08 would have solved the Metric issue, but I guess not.
The RPD has it's own OS, so I figured it would remember whatever it was programmed for. This suggests that it either shows whatever it's sent over the network (and therefore the '08 BCM only transmits in Metric), or that it resets to the default Metric units due to being unplugged from its power source.
Can anybody with an '08 and a scan gauge / HPT confirm that there are PIDs in Imperial units on an '08? I haven't heard anybody say that they could only see Metric info over the network or anything when monitoring/logging, so that means that we're left with the possibility that it may be the RPD resetting and the BCM not knowing how to send the RPD the "switch units" signal.
When we datalogged for the intake prototype last week my boost was shown in Kpa and the degrees were celsius on the laptop. What if I swapped in a 09 BCM?
Old 12-20-2010, 06:13 PM
  #103
hydroturboss's Avatar
I love RPD's
Old 12-20-2010, 07:15 PM
  #104
Stamina's Avatar
I can't speak to HPT, since I only currently have the software, but on my Dashdaq there are some PIDs that are Metric and some Imperial. Sometimes you'll have two PIDs that show the same thing but are in the different units of measurement. Try scanning for other duplicate PIDs that may be the same readings but in different units.
For instance, I've now got Boost in PSI on my Dashdaq, being calculated by the difference in the Baro sensor and MAP sensor, but I had to find both of the PIDs for them in PSI to make that work. Some of them broadcast in other units of measurement too.
I've got an '09 BCM, so maybe those extra PIDs were present in the '09+ BCMs. Perhaps that's why RPDs don't show vacuum, since they had no way of switching between two different units (Between inches Mercury and PSI on the same gauge and most wouldn't know what to do with "negative PSI", like what I've got on my Dashdaq). For the ones with analog gauges, all they'd have to do is pick a unit of measurement to use in the background (in this case it seems to be metric) for use in driving the gauge and then change the faceplate on it to match. It could be Metric or Imperial from a network point of view, and with a correctly scaled faceplate, it wouldn't matter.
If you can't find the alternate PIDs for the same thing but in the other units, I guess it's possible that the '08 BCMs have fewer PIDs.
Old 12-20-2010, 08:17 PM
  #105
Hmmm well I just looked up the part number for the 08 and 09 BCM and they are the same
Old 12-20-2010, 08:53 PM
  #106
soundjunky's Avatar
well maybe there's somethign else being missed?
Originally Posted by VRCobaltSS/TC
Update: When I had my stage kit installed I had the dealer try and get the RPD to read English, no luck. They said they called and talked to an engineer and there is no way to get the '08 BCM to send the required signal to the RPD for the switch. Bummer. So it is up for sale, RPD, the connector and install instructions. It has been proven to work on the '09s that did not come with the option since they have a different BCM.
this right here seems to spell it out.
Old 12-20-2010, 08:57 PM
  #107
so we are back to square 1. Swap in a 09 BCM?
Old 12-20-2010, 09:03 PM
  #108
soundjunky's Avatar
if I've understood one thing it's this;
  • the BCM can only be flashed once
  • if the BCM isn't flashed correctly for the car NOTHING will work; even the ECM is controlled by the BCM.
  • you need a TechII to flash the BCM
  • you need to retrieve the OS from GM, to flash to the BCM
I believe that you need the cadi module to retrieve the OS for the BCM... the candi module plugs into the TechII.
the cobalt sitting in my garage seems to me to not be able to start because the BCM is preventing it... I am not a fan of these stupid BCM's.
Old 12-20-2010, 10:10 PM
  #109
Stamina's Avatar
Yeah, basically the part number could be the same for the BCM, but the flash they put on it was/is different.
You'd then either need a fresh blank BCM to flash and get GM to flash it for you (fat chance of both of those happening IMO, but cool if you could somehow swing it), or you'd need to get an '09+ BCM.
The problem with the '09+ BCM plan though is that it wouldn't have your car's VIN in it. It therefore wouldn't play nice with your ECM. I guess you could just get a BCM+ECM that already belonged to each other, or just throw a random BCM in there and pair the ECM with the BCM using the usual steps to do that (and hoping that the VIN isn't hardcoded in yet another location that would keep you from using the BCM). The car would then think that it had a different VIN too, so you'd need to remember that when you're getting tuned, to use that VIN instead.
Old 12-20-2010, 11:49 PM
  #110
soundjunky's Avatar
I do believe that the BCM communicates with the ECM, radio, and other sub-systems;
I have understood that if the BCM or ECM sees anything wrong, the car will not be able to start.
I would not be bothered to be wrong and corrected though...
(I'd love to get this cobalt in my garage started)
Old 11-17-2011, 11:21 AM
  #111
C_A_D88's Avatar
Subd
Old 01-01-2012, 03:51 AM
  #112
SSRich's Avatar
subd
Old 01-02-2012, 01:59 PM
  #113
village idiot
casionerd's Avatar
It's an old thread.
Old 01-02-2012, 02:13 PM
  #114
soundjunky's Avatar
Originally Posted by casionerd
It's an old thread.
and your point is.... ?
Old 01-02-2012, 03:00 PM
  #115
village idiot
casionerd's Avatar
Just in case the guys were subbing for upcoming information/results. I realize they may just be doing it to keep it as reference or to read later but thought I'd post a quick note. No offense.
Old 01-02-2012, 03:48 PM
  #116
SSRich's Avatar
im keeping it so if i get a cobalt ss without RPD so i could install one.
Old 02-02-2012, 03:38 PM
  #117
mongorat427's Avatar
Old 02-29-2012, 04:04 PM
  #118
AARON-SS-TC's Avatar
Any word on this working properly on an '08?
Old 02-29-2012, 04:38 PM
  #119
soundjunky's Avatar
will a program which requires an XP operating system work properly on windows 98?
the 2008's have a different operating system, so the RPD cannot communicate properly with the car;
it will work and function, but by default it will be in metric mode ~ and you will be unable to change it into imperial mode.
This is a BCM issue - the BCM was changed between 2008 & 2009 model year cars.
I don't expect this to ever change.
Old 02-29-2012, 04:55 PM
  #120
Okay, enough said...thanks
Old 02-29-2012, 10:54 PM
  #121
C_A_D88's Avatar
How do u change an Rpd into imperial?
Old 03-01-2012, 01:56 AM
  #122
Stamina's Avatar
You switch it on the DIC in the setup menu and then the RPD follows whatever selection you make.
Old 03-01-2012, 02:26 AM
  #123
Omiotek's Avatar
yep...installs pretty self explaintory. not hard at all...
Old 03-01-2012, 05:57 AM
  #124
C_A_D88's Avatar
Damn only wanted the Rpd in imperial
Install was easy tho
Old 05-27-2012, 07:39 PM
  #125
tomj77's Avatar
i have a question on this, if ur installing this to the can port wires, what if u want to plug in an intercepter gauge as well or something else, will it not interfere with and one of them will not work like it does when u have a splitter?
Quick Reply: A quick HOW TO on installing the RPD(UAF)
