All Engines: Valve Cover- Removal and Installation.
Old 01-18-2011, 09:57 PM
KillahB's Avatar
Removal
1.Disconnect the cable from the negative battery terminal.
2.On 2005 and 2006 2.2L engines, remove the ignition coil assembly from the valve cover.
On 2.0l, 2.4L and 2007 and later 2.2L models, remove the individual coils over each spark plug.
2.0L turbocharged models
3. Raise the vehicle and support it securely on jackstands.
4. Loosen the charge air cooler inlet pipe clamps and remove the pipe.
5.Disconnect the upper engine wiring harness electrical connectors/clips, then set the wiring harness aside.
All Models
6. Remove the plastic engine cover.
7. Detach the PVC hose from the valve cover. On turbocharged engines remove the hose at the coupling, but leave it attached to the valve cover.
8.Detach the fuel line bracket from the timing chain end of the valve cover and position the assembly aaway from the valve cover.
9. On 2.0L models relieve the fuel system pressure.
Relieving Fuel Pressure
On most vehicles, the fuel pressure is relieved by staring the engine, then pulling a fuel pump fuse or relay, which disables the fuel pump and stalls the engine. however this might pull a code. So i will tell you the "proper" way to do it. This is just a recommended way of doing it.
Your fuel pressure relief setup has to include a fuel pressure gauge with a hose and suitable fitting for connecting the gauge to the Schrader valve-type test port on the fuel rail, and a bleeder valve so that you can drain off the excess fuel.
1. Remove the fuel filler cap to relieve and pressure in the tank.
2.Locate the Schrader valve on the fuel rail, then unscrew the cap and connect the gauge, run the hose into a gas can or bucket.
3.Open the bleeder valve and let the fuel flow into the container of choice.
Turbocharged
Due to the high pressure of the fuel on the turbos (2000psi) you have to due the normal method of bleeding the fuel, just pull the fuel pump fuse or relay and run the engine till it stalls. I suggest letting it sitt a couple hours after to make sure.
Now you have relieved the fuel pressure you can continue with the removal of the valve cover.
10.Remove the whole fuel inlet line.
11. Detach the ground strap from the valve cover.
12. Remove the valve cover bolts then lift the valve cover off. Tap gently with a soft-face hammer if needed to break the seal.
VOILA! you removed the valve cover.
Installation
1. Clean the gasket surface on the intake manifold, cylinder head and valve cover. Use a shop rag and some break cleaner or solvent to wipe the crap and gasket material off the sealing surface.
2. Insert a new valve cover gasket into the groove. Make sure it is positioned properly.
3. Install new O Rings and spark plug seals in the valve cover.
4. The remainder of install is the reverse of removal.
TIGHTEN VALVE COVER BOLTS EVENLY AND TO THE RIGHT TORQUE
2.0L - 71 In-Lbs
2.2 and 2.4 - 89 in-lbs
Old 01-20-2011, 09:50 AM
KillahB's Avatar
I polished my valve cover when i removed it.
Pics are coming of the whole process
Old 01-21-2011, 05:49 PM
KillahB's Avatar
No one likes my post
Old 01-21-2011, 05:53 PM
07BoostedG5's Avatar
Great post, No brainer item to remove lol
Your cover looks good
Old 01-21-2011, 07:46 PM
KillahB's Avatar
yea, my first post, was making it an easy one. Any suggestions on future articles haha
Old 01-28-2011, 01:13 AM
chrisjaldin's Avatar
Where is the polishing process? I want to polish mine. I already have my valve cover down...Hope you still have the pics KillaHB
Old 03-05-2011, 11:58 PM
corn gas ftw....
ssblackstealth's Avatar
good write up, need pics! lol
Old 03-06-2011, 11:13 PM
slobalt08's Avatar
Yeah I highly stress being careful with torquing the vc screws. In fact torque wrenches IMO are highly evil. Despite following recommend torque #, I almost ALWAYS break screws torquing them. So BE CAREFUL torquing the VC screws. I already broke one. -_-
Old 03-06-2011, 11:14 PM
myfakeevo's Avatar
thank god for this, the first time i did it, i put it on upside down and i couldnt understand why oil was going everwhere
Old 08-10-2011, 01:21 PM
Window Licker
sjc0013's Avatar
how critical is it to relieve the fuel pressure before doing this on an lsj?
Old 08-10-2011, 07:29 PM
noorj's Avatar
lolllzzz
Old 08-10-2011, 10:00 PM
myfakeevo's Avatar
the fuel rail holds about a 1/2 a cup of fuel in it, its up to you if you want fuel all over the place.
Old 08-10-2011, 10:03 PM
Window Licker
sjc0013's Avatar
well if thats the worst that will happen, **** it lol
Old 08-10-2011, 10:42 PM
myfakeevo's Avatar
the easiest way is to remove the fuel pump relay in your engine bay, start the car and let it stall out.
Old 08-10-2011, 10:50 PM
Window Licker
sjc0013's Avatar
So just pull the fuse and then im good to go?
Old 08-10-2011, 10:53 PM
myfakeevo's Avatar
relay.
Old 08-10-2011, 11:04 PM
Window Licker
sjc0013's Avatar
relay.
Awesome. Valve Cover will soon be gold.
Old 10-05-2011, 06:02 PM
mrgrinch's Avatar
sub'd
Old 10-05-2011, 06:20 PM
BlackARCA06's Avatar
Will the car start right back up when putting the relay back in?
Old 10-05-2011, 06:22 PM
Window Licker
sjc0013's Avatar
yep
Old 03-27-2012, 10:53 PM
jrmotosports 88's Avatar
click
Old 03-28-2012, 10:21 AM
06cobalt racer's Avatar
for me when i removed mine on my 06 ss/sc i didnt need to disconnect the fuel line at all. i just loosened the i think 2 bolts that hold it down and moved it out of the way.
Old 04-01-2012, 08:50 PM
tomj77's Avatar
why do u need to relieve fuel pressure on lnf? its direct injected, there shouldnt be any fear of fuel coming out anywhere.
Old 04-02-2012, 08:48 AM
the reason they say to relieve the pressure is because they want you to disconnect the fuel line. (on lsj, not sure how the fuel line is routed on lnf) but even with the lsj you dont need to. i didnt. i just pulled it out of the way a little
Old 04-02-2012, 05:01 PM
tomj77's Avatar
fuel line isnt in the way of the valve cover at all on the lnf.
Zo6balt (11-30-2020)
Quick Reply: All Engines: Valve Cover- Removal and Installation.
