Nitrous Oxide N20
09 SSTC 75 Shot?
Old 09-02-2010, 10:25 PM
Tgustafsonjr's Avatar
09 SSTC 75 Shot?
Currently deployed and my car is sitting in my local shop. They want to hook up a 75 shot. Just wondering if anybody has tried a 75 shot on the TC?
Old 09-02-2010, 10:27 PM
gdubs's Avatar
Direct Injection and NOS..... Not a smart combo. The injectors are very very sensitive and if you break one....get your money ready
Old 09-02-2010, 10:45 PM
Ok thanks
Old 09-03-2010, 10:22 AM
Kelu's Avatar
I think you were referring to a dry shot, right?
If there is Wet shot I don't see the issue with a DI engine, can you help me out?
Old 09-03-2010, 10:50 AM
ebristol's Avatar
Do it. Someone has to be the first.
Old 09-03-2010, 07:09 PM
Kelu's Avatar
A great guy with a LNF Kappa back in begining of 2008:
i started with a 75 single nozzle in the cold side charge pipe. worked fine. i then put a purge solenoid to the intercooler and moved to a 100 direct port shot. i popped 4 holes in the intake mani, tapped into the schrader on the fuel line leading to the mechanical pump and sprayed away. then in 50 horse increments, i worked up to a 200 shot. (lemme tell you what, 24lbs of boost and the spray make this thing a monster, i cannot wait till hptuners finishes that thing). now before you people all call me crazy, let me tell you that i was scheduled to go in for surgery in sept and knew i was going to have the winter away from work to play a little while i healed. so i got the monster jets out and figured a 300 shot would probly tell me where the weak point of this motor was. and it did. i'm figuring it took about 600 horse (260 stock, plus mods and boost, and 300 from n2o) before she let loose but heres the result.
For hole story:
Engine build - Pontiac Solstice Forum
Old 10-02-2010, 01:55 AM
pantherqs's Avatar
75 shot is fine. I finally got the 100 dialed in perfect the other day after some misshaps, hitting the track tomorrow. Going to work into a 125 to 150 by the end of the day and let god sort out the rest. If she blows, no biggie, just hoping the clutch will hold together. Biggest bitch so far has been keeping EGT's in check. Lots of meth and lots of fuel and stock timing alleviated that though.
3 10's ready to go, can't wait.
Old 10-02-2010, 01:58 AM
Boss002's Avatar
wow!!
Old 10-02-2010, 02:43 AM
blacklightmachine's Avatar
guy named chomo did it here already back in 08 when the car came out.
Old 10-14-2010, 07:49 PM
FF_ace's Avatar
his name was choko and he did it back in 08 ran a 13.1 or something stock with a 150 shot then blew motor he rebuilt it then the car caught fire
Old 10-16-2010, 02:38 PM
cardelino18's Avatar
so a wet 75 shot is fine? need to be tune or it will keep A/F the same?
Old 10-16-2010, 02:45 PM
Garret's Avatar
I'm wishing my LNF was RWD and on a 200 shot hahah
Old 10-18-2010, 01:18 PM
ebristol's Avatar
So it was a safe setup? lol
Old 10-19-2010, 11:59 AM
2006RedCobaltSS's Avatar
I'm getting ready to install my nitrous kit this week. Looking to start with a 50 shot and work up from there. Where do people with the LNF tap for the fuel?
Old 10-19-2010, 03:09 PM
Kelu's Avatar
There is a test port before high pressure fuel pump, you can't miss it.
Old 10-19-2010, 05:25 PM
cool, i didn't know if I should go off that or not. Hopefully have it installed tonight or tomorrow
Old 10-25-2010, 07:27 PM
marcusicp's Avatar
So did you get it installed?
Old 10-26-2010, 12:04 AM
Was actually doing it tonight and needed a certain size tap. Also, switching to a msd wot switch
Old 10-26-2010, 05:22 AM
Kelu's Avatar
Here is an update on my case:
LNF Kappa (Opel GT) with nitrous
No nitrous
HP: 205KW = 274whp or 278 whp in metric
Torque: 430Nm = 317 ft/lbs
With 50hp shot nitrous from 3500rpm
HP: 230KW = 308whp or 312 whp in metric
Torque: 445 Nm = 328 ft/lbs
Difference:
- 35whp and 11 ft/lbs
Some personal notes:
Now I understand why I don't feel it when I spray on streets/race because there is only 11 ft/lbs difference.
Normally a 50hp shot should be 50 whp but because my bottle has no heater so it has way lower nitrous pressure (600psi instead of 1000psi) I get less power increase, also because the nitrous is less I noticed -10% adjusting on fuel trims so it runs very rich, with a proper nitrous pressure I will approach to 50whp.
I did over 10-12 runs on the dyno, I have played with AFR and timing on the high rpms but I didn't saw many gains so I went back to the rich baseline.
I'm about to buy a bottle heater and nozzles for 75hp and 100hp shots, depending how fast I will get that from US I will have more results updated.
Old 11-09-2010, 06:16 AM
Nothin Stock
gotboost?17's Avatar
Turbo Johnny
02-21-2019 09:41 AM
06blackg85ss
83
01-18-2017 04:35 AM
supajut
12-19-2015 04:06 PM
dennis69
09-22-2015 08:56 AM
dennis69
09-21-2015 11:55 AM
Quick Reply: 09 SSTC 75 Shot?
