Best hp improvement to install Water/Methanol Injection
I just notice that there are 3 ways to inject water/methanol from ZZP products:
1. Drilling a hole into the intake pipe
2. Using the Throttlebody spacer plate with ports
3. Using the M62 spacer plate with ports
I wonder which is more effective and produces better results and which one is the most common?
Regarding brands, I think AEM has the best pump for its consistency. What do you think?
Which would be the correct way to setup a nitrous and methanol injection? together at the intake pipe?
After the s/c would be the best because that has the best tendency to bring all the cooling and octane effects directly into the head and closest to the combustion chamber. Atomization doesn't matter here just look at fuel injector location. Closer = better.
i had mine injected in the intake tube for a month but i got a good deal on a tb spacer so i took my intake meth tap off the intake and its chillen in my garage now , i didnt dyno either so i cant tell you if there's a power difference, afrs and iat's were the same in both situations thou !
According the AEM specialities, it should be on the intake pipe to give the alcohol mix time for atomization but Tim, from ZZP and others, that the closer to the combustion chamber the better, atomization doesn't matter...
In search of my best possible setup of water/meth injection, I gather up some information from water methanol vendedors followed by their links for more information:
DevilsOwn: ..." Option 6, Intake manifold, this option is best for max cooling."...
Where to locate your alcohol-water injection nozzle
Snow Performance: ..."Positive Displacement Supercharger: Roots style (B&M, Eaton, Magnuson, etc.) or twin screw (Lysholm, Kenne Bell, Whipple, etc.) Mounting the nozzle before this style of blower is perfectly safe and actually provides some additional benefits. The small amount of water-methanol fluid isnt harmful to any rotor seals or surfaces or coatings, and it helps to seal the clearances and condense the air some more, resulting in a more efficient output. Additionally, it keeps the rotors and housing MUCH cooler, which reduces heat transfer to the rest of the intake and air charge."...
Link: Snow Performance: FAQ gasoline
AEM:.. "The nozzle should be placed in your intake pipe, before the throttle body. You want to give the methanol time to atomize with the air before entering into the engine"...(email from eliu@aempower.com, link shows graphs of what he said)
AEM Water/Methanol Systems for Gasoline Engines - Water/Meth Kits - Wideband O2 UEGO, Water/Methanol, Stand Alone Engine Management, Piggyback F/IC, Tru Boost Controller, Gauges, Automotive Performance Electronics
And Zommer from ZZP, told me: below the blower.
So, at the end, which is the best place to put the nozzle and output most boost and hp?
wanna hear some opinions.
1 Post
Yes, it is safer to have the filter in place in case the meth mixture has dirt/ tiny rocks or particles in it, which it could lead to damage to the meth nozzle or TB or intake manifold or the engine.. if your running "meth tune" and a piece of gets stuck in the nozzle, you could possibly damage the motor because of knock, timing, fuel, etc..
I'll just say this - it's better to be safe then sorry.. i know it's happen to me..
tested both, one at the throttle body spacer and had e on my after market intake about 5 inches from the throttle body. the nozzle(s) being placed in the intake gives you stronger and more broad power curve. there was a 4 horse power advantage over the sprayer being at the throttle body spacer. this seems to work better as your boost is climbing and able to have the methanol start at a lower boost level. All you have to do from this point is trim your fuel level input down to accommodate for the methanol. a few things were trial and error, but these steps gave me the best hp results. I have the Intense stage 4 with a 2.6 instead of 2.7 pulley w/60lb injectors, weapon-r intake, 75mm throttle body & a (spacer not be used), Bad-Mab shorty header 3" flange, 3" downpipe w/o cat, megan 3" cat-back, dual-pass end plate and a added intercooler after stock intercooler and some head work done. Had inside of supercharger machined were it connects to the throttle body to allow enough clearance for the larger throttle body.
you could reuse the ports yes, as far as running them both at the same time will not in the same port lol you'll need another. and meth and nitrous have separate "windows" for when they spray, and they may (probably do) overlap. I haven't read of many people doing this but there shouldn't be any issues if you're using them for the right reasons and in the right places.
Delta coupe
09-30-2015 08:11 AM
